adsm08 2,643 #51 Posted November 24, 2019 (edited) On 11/20/2019 at 3:41 PM, squonk said: Non flammable brake cleaner is the bomb for bees. You can shoot them down like WWII Zeros. But it is much more entertaining, and more realistic to do it with flammable stuff. I love watching yellow jackets fall from the sky as their little wings burn off. Just like a Zero. True starting fluid, with a lubricant, is OK to use sparingly. Ether is bad. Ether dries out the rings, to the point where it can't build enough compression when cranking to start without it. via Imgflip Meme Generator Edited November 24, 2019 by adsm08 Share this post Link to post Share on other sites
