AHS 1,443 #1 Posted November 8, 2019 Ok, it’s a C160. I know 8 speeds, they have 4 bolt that mount them to the tractor.. simple, and heavy! I am clueless about automatics. To change it; Is it just the 8 speed and a shifter plate? I am looking for something for snow blowing. Share this post Link to post Share on other sites
ebinmaine 68,352 #2 Posted November 8, 2019 There's several sheet metal differences. I'll bet I could find some here..... Share this post Link to post Share on other sites
pfrederi 17,874 #3 Posted November 9, 2019 Control linkage issues but nothing insurmountable. What is wrong with your hydro??? Share this post Link to post Share on other sites
AHS 1,443 #4 Posted November 9, 2019 @ebinmaine there is just sunstrand and Eaton (hydro) and 8 speed in wheel horse, right? There is no auto? 1 Share this post Link to post Share on other sites
ebinmaine 68,352 #5 Posted November 9, 2019 3 minutes ago, AHS said: @ebinmaine there is just sunstrand and Eaton (hydro) and 8 speed in wheel horse, right? There is no auto? Correct 1 Share this post Link to post Share on other sites
ZXT 2,401 #6 Posted November 9, 2019 3 minutes ago, AHS said: @ebinmaine there is just sunstrand and Eaton (hydro) and 8 speed in wheel horse, right? There is no auto? A hydro and auto are one in the same. What's wrong with yours that makes you want to swap it out? 1 Share this post Link to post Share on other sites
lynnmor 7,354 #7 Posted November 9, 2019 I would much prefer the hydro over the 8 speed for snow work. 2 1 Share this post Link to post Share on other sites
AHS 1,443 #8 Posted November 9, 2019 1 minute ago, lynnmor said: I would much prefer the hydro over the 8 speed for snow work. Really? Why? Just curious. I have both the hydro and the 8 speed... and I have only driven the 8 speed in the snow. I would think the hydro in the snow would jut spin... Share this post Link to post Share on other sites
ebinmaine 68,352 #9 Posted November 9, 2019 3 minutes ago, AHS said: spin I'll share what I do to cinnamon on Sunday. It's all about being properly weighted. Some like hydros for speed and convenience. Trina and I both prefer a gear drive. 1 Share this post Link to post Share on other sites
ZXT 2,401 #10 Posted November 9, 2019 1 minute ago, AHS said: Really? Why? Just curious. I have both the hydro and the 8 speed... and I have only driven the 8 speed in the snow. I would think the hydro in the snow would jut spin... They are generally preferred in the snow due to the fact that you can vary your speed almost indefinitely - you essentially have an unlimited number of "gears". There is no slipping the clutch or having to adjust the engine RPM to achieve your desired speed. They'll both spin - the transmission type has nothing to do with the traction of the machine. That's like saying you wouldn't drive a car with an automatic in the snow because it would just spin. 1 1 Share this post Link to post Share on other sites
AHS 1,443 #11 Posted November 9, 2019 1 minute ago, ZXT said: They are generally preferred in the snow due to the fact that you can vary your speed almost indefinitely - you essentially have an unlimited number of "gears". There is no slipping the clutch or having to adjust the engine RPM to achieve your desired speed. They'll both spin - the transmission type has nothing to do with the traction of the machine. That's like saying you wouldn't drive a car with an automatic in the snow because it would just spin. That’s true. Ok. The throttle is always up!👍 I have to get wheel weights!! 2 Share this post Link to post Share on other sites
ebinmaine 68,352 #12 Posted November 9, 2019 1 minute ago, AHS said: wheel weights Fluid fill tires. That's the way to go. 1 Share this post Link to post Share on other sites
AHS 1,443 #13 Posted November 9, 2019 What is Cinnamon? A hydro or an 8 speed? @ebinmaine Share this post Link to post Share on other sites
rjg854 11,484 #14 Posted November 9, 2019 If you have to do a lot forward and reverse work, there's no need for all the clutching and shifting. Share this post Link to post Share on other sites
ebinmaine 68,352 #15 Posted November 9, 2019 3 minutes ago, AHS said: What is Cinnamon? A hydro or an 8 speed? @ebinmaine 8 speed 1 Share this post Link to post Share on other sites
AHS 1,443 #16 Posted November 9, 2019 1 minute ago, rjg854 said: If you have to do a lot forward and reverse work, there's no need for all the clutching and shifting. True!👍 Share this post Link to post Share on other sites
ebinmaine 68,352 #17 Posted November 9, 2019 4 minutes ago, AHS said: What is Cinnamon? A hydro or an 8 speed? @ebinmaine All four of our tractors are Manual. 1 Share this post Link to post Share on other sites
AHS 1,443 #18 Posted November 9, 2019 @ebinmaine you said just windshield washer for tire filling or what else? Rimguard? Share this post Link to post Share on other sites
953 nut 55,773 #19 Posted November 9, 2019 I use Recreational Vehicle antifreeze. 1 Share this post Link to post Share on other sites
rjg854 11,484 #20 Posted November 9, 2019 That will work Share this post Link to post Share on other sites
ebinmaine 68,352 #21 Posted November 9, 2019 5 minutes ago, AHS said: Rimguard If you can get it... That would be ideal. Heavier than any other filling fluid except calcium chloride. That's what is in Cinnamon Horse's tires all around. There's 255 POUNDS of fluid. Then another 100 steel. Share this post Link to post Share on other sites
The Tuul Crib 7,337 #22 Posted November 9, 2019 Hey I prefer an eight speed over the automatic I feel that I have better control with motion jmho. 1 Share this post Link to post Share on other sites
Darb1964 1,055 #23 Posted November 9, 2019 Auto lift is the most important thing to me when it comes to snow blowing. I still have good upper body strength, but the one season I used a Manual lift I had tennis elbow bad. 2 Share this post Link to post Share on other sites
AHS 1,443 #24 Posted November 9, 2019 9 hours ago, ebinmaine said: If you can get it... That would be ideal. Heavier than any other filling fluid except calcium chloride. That's what is in Cinnamon Horse's tires all around. There's 255 POUNDS of fluid. Then another 100 steel. Calcium chloride, doesn’t that have rusting capability’s? Rimguard does not? @ebinmaine Share this post Link to post Share on other sites
ebinmaine 68,352 #25 Posted November 9, 2019 13 minutes ago, AHS said: Calcium chloride, doesn’t that have rusting capability’s? Rimguard does not? @ebinmaine It is. Yes. It shouldn't be in contact with bare metal. If in a tube it's much less of a problem unless a leak occurs. Calcium chloride can weigh as much as 13.5 pounds per gallon. That's what I'll likely use to fill the tires of Colossus when I get it going. 1 Share this post Link to post Share on other sites
