Similar Content
By 953 nut
I have a few basic electrical system diagrams that are helpful in understanding how the wiring system works. They are not specific to any particular tractor and do not include safety switches. All use the 5 post ignition switches 103-991 for Magneto and 103-990 for Battery Ignition. I failed to include fuses in the Starter Generator drawing, this is an over-site and I would encourage fuses be used as shown in the other two drawings.
Hope this is helpful.
Magneto Ignition system with electric start and solenoid.
Battery powered ignition system with points, condenser, solenoid and electric start.
Battery powered ignition with solenoid, points, condenser, Starter Generator and a mechanical voltage regulator.
We have uncovered a shortcoming in the factory wiring diagrams for S/G battery ignition systems with a four terminal voltage regulator. The wire from the regulator "Gen" terminal to the S/G "A" terminal was omitted. This drawing should clear that up.
By rwlvt
Hi folks,
I tried to help a friend with a Toro 520H that won't start.
https://photos.app.goo.gl/19fPX79LGMPCBcnB6
(Attempting to insert a photo by URL doesn't seem to be working.)
Here are some identifiers for the engine:
Engine Model: P220G-I/109556
P/N941811
S/N: A973636148
I went through the usual--checking for spark. I'm getting spark in both cylinders. So, i'm looking at gas. There is a fuel pump on the side of the engine.
https://photos.app.goo.gl/RY4hHAfLLGeyCBaS8
I pulled the gas line below it and am getting gas from the tank. I pulled the line above it and cranked the engine. I wasn't getting anything! So, I assumed it was a bad fuel pump. I ordered and installed a new fuel pump, but still no luck. This is a vacuum actuated pump, so I pulled the pump and stuck my thumb over the tube while I cranked the engine. I expected to get either a vacuum or compression. I got neither. Any thoughts about where I go from here?
Thanks in advance,
Ron
By Rob R
Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216. He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
By Jon Paulsen
Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
