Pullstart 68,521 #1 Posted November 4, 2019 Rylee’s K241 10 horse Kohler in Filly has about 3/4” or so of in and out slop in the governor shaft. It this a tell tale sign the governor has exploded inside? Luckily it runs fine for the time being, but if we need to open it up for some replacement governor work, well then Rylee will get a crash course on engine work! Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted November 4, 2019 Sounds to me like somethings not really right inside if it moves that much. Problem is they're so hard to get to because the camshaft is in the way. You have to drive that long pan out to get camshaft out to even get to the governor gear . I just got done doing one in one of these motors here. Rylee would be learning more about the heart beat of Filly. Do you have another motor to put on it while you are working on it? Keep us posted!! 1 Share this post Link to post Share on other sites
Pullstart 68,521 #3 Posted November 4, 2019 I don’t have another runner to pop in, but she doesn’t necessarily need it to run before the weekend’s over to get to work on Monday 2 Share this post Link to post Share on other sites
Shynon 7,505 #4 Posted November 4, 2019 I think there is a sleeve on the shaft to stop the movement, you will have to carefully remove the brass nut. I can get pictures when i get home 1 Share this post Link to post Share on other sites
WHX?? 53,325 #5 Posted November 4, 2019 (edited) I have also saw where there is a real small clip ring on the shaft to limit movement so that is maybe what Tom is talking about. The groove is real small and the clip is just a wire and pretty dainty....easy to dislodge. Don't remember if its in front or back of the nut. Parts manual does show some kind of hooby doo ther … # T1... calling it a bushing. Edited November 4, 2019 by WHX24 1 Share this post Link to post Share on other sites
pacer 3,177 #6 Posted November 4, 2019 Lordy, Tool Crib is right, its virtually a complete teardown to get to that dang thing!! 1 3 1 Share this post Link to post Share on other sites
WHX?? 53,325 #7 Posted November 4, 2019 (edited) Yup that's the last part to come out and the first to go back in during a rebuild! Fortunately very few problems with tho but I have seen where the arm is staked on the shaft comes loose. Edited November 4, 2019 by WHX24 Share this post Link to post Share on other sites
Pullstart 68,521 #8 Posted November 4, 2019 I climbed up to snap a few pics. Sorry for the poor lighting... Without the nut, there is a ton of slop... but the shaft won’t pull out. Share this post Link to post Share on other sites
WHX?? 53,325 #9 Posted November 4, 2019 1 minute ago, pullstart said: but the shaft won’t pull out. No.... shaft has to come out from the inside. You do want the arm to ride in the center of the fly gear tho. That's what the spacer does. Maybe older K's had the dainty clip??? You have to loosen the pinch bolt and slide the throttle arm off to get at the spacer/clip. Then will have to reset it but no big deal procedure is in the manual. That second pic has got way too much arm hanging out. 1 Share this post Link to post Share on other sites
Shynon 7,505 #10 Posted November 4, 2019 2 hours ago, WHX24 said: Parts manual does show some kind of hooby doo ther … # T1... calling it a bushing. That's what's missing, pull the brass nut and put one on. Share this post Link to post Share on other sites
Pullstart 68,521 #11 Posted November 4, 2019 Does anyone have one on a shelf by chance to measure the length for me by chance? That would be awesome to be able to perform an external fix! Share this post Link to post Share on other sites
Shynon 7,505 #12 Posted November 4, 2019 If you have a small groove you have to have a clip on it, if no groove then the bushing/sleeve. 1 1 1 Share this post Link to post Share on other sites
Pullstart 68,521 #13 Posted November 4, 2019 So basically if I have 13/16” slop, make a bushing that long and give it a whirl? 1 Share this post Link to post Share on other sites
mflowers 86 #14 Posted August 9, 2024 On 11/4/2019 at 4:37 PM, Pullstart said: So basically if I have 13/16” slop, make a bushing that long and give it a whirl? I know this is an old post but I have a similar problem - assembled the motor and put the bushing/sleeve on the wrong side of the flag 🤦🏼♂️. how did this work out? I’m thinking of adding another sleeve to the front end, from the outside after removing the brass nut. I found one on McMaster-Carr that’s 3/4” long and I’m thinking that’s “close enough”. Share this post Link to post Share on other sites
Pullstart 68,521 #15 Posted August 9, 2024 36 minutes ago, mflowers said: I know this is an old post but I have a similar problem - assembled the motor and put the bushing/sleeve on the wrong side of the flag 🤦🏼♂️. how did this work out? I’m thinking of adding another sleeve to the front end, from the outside after removing the brass nut. I found one on McMaster-Carr that’s 3/4” long and I’m thinking that’s “close enough”. It doesn’t look like the parts diagram has any interference. I’d say you are on the right track. @WHX?? and @Shynon have more experience inside these than I do. With that said, I can’t imagine any interference would be in play there. Share this post Link to post Share on other sites
WHX?? 53,325 #16 Posted August 9, 2024 I would think if the bushing/spacer is on the back side of the shaft the flag would not rest on the center of the flyweights or the shaft would not set in the boss in the block. If it does another spacer might just work. Share this post Link to post Share on other sites
Pullstart 68,521 #17 Posted August 9, 2024 You should be able to tell if it sits in the block fully. The exterior stack up with the nut and throttle arm should yield about 1/4” or less shaft stick out. 1 Share this post Link to post Share on other sites
mflowers 86 #18 Posted August 9, 2024 When I originally put it in I checked that the flag lined up with the governor pin, so that’s not a concern, and it does go fully into the boss in the block. 2 Share this post Link to post Share on other sites
