Marc Gall
Snow Blower Question 315-8
Marc Gall
Looking for some advice/help/guidance:
I have a 315-8. Model # 73450 with a Kohler 15HP Engine. We’re in the process of moving to Northern Michigan. The new home has a pretty steep and long driveway, so I’m in the market for a snow blower for my Wheel Horse. I found a snow blower Model # 79262 - Serial # 5900999.
Here’s my questions/concern:
1 - Will this Snow Blower fit my 315-8?
2 - Harder question, will my 315 be able to handle a steep drive. The drive is around 30°. I am planning to purchase rubber chains and wheel weights.
Any advice is greatly appreciated!
kasey54
I think traction will be the only question mark. Never worked a grade like that.
Steering may be an issue too. Asphalt or gravel drive?
Marc Gall
Asphalt Driveway.
kasey54
I've read here, that front chains help with the steering.
gwest_ca
The 79262 fits lawn tractors with vertical engine crankshaft so the belt drive is different.
These models should fit I think. More at the end.
Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar.
1973-74 model 6-6212 plus 6-9113
1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate)
1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank)
1976 model 6-6215 - This one -
1976 model 66-42ST01 - and this one are likely identical. The model number format changed.
1977 model 76-42ST01 - This one
1978 model 86-42ST01 - and this one
1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year.
1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute)
1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels)
1983 model 06-42ST03 - (First model to use skids)
1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft)
1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft)
1990 model 06-42ST06
1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers)
1993-2001 model 79360
2002-2007 model 79362
The snowthrower listed for you tractor is model 79362 with this note - 79360 Snowthrower will fit; requires Adapter Kit 105-1503 which consists of a new driven pulley and a support for the chute crank.
I do not know what is different about the pulley. Could be diameter and/or shaft size.
Hopefully someone reading this has a model 79362 and will comment.
Garry
Marc Gall
Thank You. Wow!  That’s a lot of good info. I just found a 79362 Snow Blower not too far from me.  Just it be clear. This snow Blower will fit my 315-8, right?  Thanks again
WVHillbilly520H
YES
gwest_ca
If you get the 79362 could you give us the dimensions of the driven pulley?
I suspect the change to an electric pto clutch has something to do with it.
Garry
lynnmor
If your driveway slopes to the side, be aware that rubber tire chains have no control to prevent sideways slip.  Those rubber straps are a toboggan side to side.  I have one spot that I learned to handle very carefully after doing a 180 and now work the high side first and take subsequent cuts with the snow bank preventing side slip.
