![Sir_warden](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
By CasualObserver
Owners manual for the Single cylinder snowmobile engines.
12 pages 1.33MB
1970 295 Safari snowmobile model 9-0011 - 1-cylinder
1970 309 Safari snowmobile model 9-0021 - 1-cylinder
1970 309W Safari snowmobile model 9-0061 - 1-cylinder
1970 355 Safari snowmobile model 9-0031 - 1-cylinder
1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
By CasualObserver
Copy of the Instruction and Parts List for the 1970-72 snowmobile trailer offered by SnowCo that was branded as a Wheel Horse.
Dated 6-1-69
Model 9-0501 (Snow Co model 637 single)
Model 9-0511 (Snow Co model 863 double)
Double serial number 2219 - Build date 09/69 - Most likely considered a 1970 model
By Ron B.
Good day to all,
My project, although it's not a tractor, it's still a horse! What I'm working on is a 1970 Wheel Horse Safari 309w. It has the Kohler k309-1t with a Tillotson HR-41A carb. The engine runs but, the carb is a bit buggered still. So, I'm looking for as much information about the HR-41A carb as possible, if possible. I believe I have it figured out but, I'm just looking for some confirmation. I have replaced gaskets and diaphragms, and at this moment, I do have a new needle and seat coming. After the initial rebuild, I could not get the carb to pump gas until I removed the, #18. diaphragm (pulse). So, in a nut shell, I'm looking to find out if I'm headed in the right direction with this carb.
Any and all info would be greatly appreciated!! Thanks!!
By Wade
Not sure if I did this right but thought some may not have ever seen a Wheel Horse with a track. Found it in c/l.
