Ol Red
C-121 48” deck belt
Ol Red
Hey Guys,
I am new to the forum just bought a c-121 with a 48” mower deck. I need to replace the deck belt, but can’t seem to locate the deck model # so I can find the right belt. Does anyone happen to know the belt # or model # to the 48 in deck? I have all the original parts manuals but can’t find it listed anywhere. Thanks for the help!
gwest_ca
Welcome to the forum.
This may not be the model deck you have but the belts will be the same.
Decks are sized by their width of cut - not the width of the deck.
Click on the fuzzy picture.
Garry
Ol Red
Ok great thank you. So in other words if the deck measures from one side of the deck to the side discharge of the deck  appx 48” it may be the 42”? Maybe thats why the belt was difficult to locate ...
peter lena
if you have a tractor supply near by , you could just bring in your old belt and match it up, i usually go 1" shorter to make up for stretch , don,t for get to grease your spindles , and check out belt tension pulley for noise or sloppy movement. pete
gwest_ca
That is exactly why I mentioned the deck size just in case you were not aware.
Here is the 42" side discharge deck. There is also a 42" rear discharge that may use different belts. I always look them because don't like guessing.
Clicking on the picture takes you to a page with the belts listed. Saves having to download a file that may not be what you have.
Belts will be the same for all 42" SD decks of this style.
Garry
Ol Red
Thank you guys, I appreciate the help and resources
The Tuul Crib
:text-welcomeconfetti:to :rs:
:wwp:
oldlineman
Mower hight adjustment is on right side of 42"deck and on left side of 48" deck.
Lee1977
42" deck are bad to crack under the deck cutting height adjuster and rust holes in the deck there. This is the way I fixed mine. Added metal  on each side bolted in place as I can't see to weld any more.
