byrdman
Wheel Horse C-120 automatic model #
byrdman
Hello Members I just joined Red Square wheel horse and need some help with my c-120 auto.. I want to find and download a service manual,parts manual and owners manuals. Toro Wheel Horse needs a 5 digit model number to access the files but  the previous owner removed this one so I don't have it. I was wondering if one of you guys would give me a model number to use if you have one of these machines, I would really appreciate it. Thank you,
Don
ebinmaine
:WRS:
@gwest_ca might be able to help out.
pfrederi
Welcome you can find manuals here. on red square in the manuals section.  This is a link to a C0120 Auto for 1974.  They were made for three years but not much changed.
Edited by pfrederi
Pullstart
Hey @Don Byrd, you made it!  Hopefully you’ll be able to find what you need here with the manuals on the site.  :text-welcomewave:
Fellas I have a feeling from emailing with Don that he might need assistance with the tow valve on his tractor.  I don’t think I have the same auto trans on any of mine so any help and assistance he’d greatly appreciate.  The engine runs great but the motion control doesn’t do anything to get him moving.
I forgot to mention on email, if the trans fluid is red, keep to ATF for good.  If it’s amber/brown, stick with 10W30 motor oil whenever you do fluid and filter changes.  They used both from the factory but they shouldn’t be mixed.
The Tuul Crib
:text-welcomeconfetti:to :rs:
:wwp:!!
pfrederi
Left side  should be a screw driver to close it (Turn clockwise.)
Pullstart
Do you turn it until it stops?
byrdman
:wwp:!!
51 minutes ago, ebinmaine said:
:WRS:
byrdman
Hi Tool Crib,would you happen to have a model number for me? Thanks,
Don
pfrederi
Yes but do not put a lot of toque on it snug is good.
pfrederi
Don
 Model number changes by year 1974 -1977
The Tuul Crib
Don
No l dont Don but ill bet gary does .
pfrederi
1974 1-0490 (as you have a Kohler Techy engine was different model)
1975  1-0491
1976   61-12KS01  also ending in S02 S03 S04
1977  71-12KS01   and S02
Edited by pfrederi
gwest_ca
I think this may be a 1979 C-121 Auto.
Post all the numbers off the engine data decal including the serial number.
What is in this circle in your photo - just below the dash panel?
Garry
Sparky
The larger dash tower looks like the 1978-1979 C series to me.
roadapples
Yes, newer than 74 with gas tank under the seat..
gwest_ca
This 1979 service manual is appropriate for your tractor. I'm thinking your model name will be C-121 Automatic and model number will be 91-12KS01. Click on the picture.
Garry
Pullstart
I received this email from Don last night.  I think we done good!
I got lots of replies to my post about manuals and even dowloaded a parts manual.I know for sure I need a headlight lens #103771, and a clutch brake #104730 and a lower steering shaft bushing # 637. No hurry tho, I have plenty time to locate them. The tow valve did the trick,it screws in and out instead of pushing. I drove it around the house, I like it a lot. Thanks again for all your help. Don
Sparky
RED SQUARE to the rescue!!
Sparks58
I am picking one up today and can let you know what is on it if that will help you.
