Sean O 0 #1 Posted October 7, 2019 I’m looking for a snow blower attachment for my C-165. Anybody know which wheel horse snow blower attachments are compatible with the c-165?? Thanks! Sean Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted October 7, 2019 Welcome to the forum. For a single stage which is the simplest any one in this list from 1973 and newer will fit. Look at a parts list so you are aware of the loose pieces that often get separated when sold. Snowthrower DNA Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 2002-2007 model 79362 2 Share this post Link to post Share on other sites
Sean O 0 #3 Posted October 14, 2019 Thank you for the info. I just picked up the 79360 model. Appreciate it! Share this post Link to post Share on other sites
