Sarthurs01
Pulley recommendation
Sarthurs01
recently bought a 22 hp motor for my puller and was wondering what your guys input on what pulley sizes to use. thanks!
Spareparts
Need more info. tire size, rpm you will be running and in what gear. On my grandson's puller we have a 18hp V twin B@S running in
2nd gear hi side with a 5091 peerless, tire size is 23X10:50X12, RPM is 3200 and it's speed is 3.4 MPH. That is with a 4" 5/8 pulley.
That MPH is the limit for his weight class and is very strict of DQ'ed.
Sarthurs01
Tire size is 23x10.50x2 have to check on the rpms tho. Right now it has a 8hp brigs with a 2.5 inch pulley and I’m pulling 2nd low. I’ll have to look in to a mph rule to make sure too. THANKS!
TonyToro
I am still very new to pulling. I have been gathering information over the past few years from this group and my pulling club. Us Wheel Horse guys run an unpopular tractor. Most guys are running the Cub Cadet but I like to be different.
We run a 4” on the engine at 3600rpm 2 gear high. We are limited in this class to 2.5 mph so we play with the throttle during the pull to watch our speed.
is this stone boat or transfer sled?
WHNJ701
when I got my 854 wheelhorse it was setup as a puller or something, it had  like a 4" pulley on the engine and a 1" on the transaxle.  was told it did wheel stands and had a set of bars on it.  I put the the tractor back to stock and put a mower deck on it and used it.
fast88pu
I'm running stock 8 speed rear pulley and stock 8 speed front pulley at 4500 rpms in 3rd high. Hang on lol
  • Haha 2
TonyToro
Nice!!
What are you running for an engine?
fast88pu
43 minutes ago, TonyToro said:
Nice!!
A built 670 predator
TonyToro
That will work! Lol
I really like the sounds of those twins.
What class is that one in?
TonyToro
How are you doing with your tractor?
fast88pu
5 hours ago, TonyToro said:
That will work! Lol
Stock altered 1050 lb
Sarthurs01
I haven't pulled it yet with the 670 yet but just about have it all built, few more weeks and it should be just about done.
ebinmaine
Any idea roughly how fast that is? Not like screaming. Must be eight or nine?
ebinmaine
Got any pics?
fast88pu
Probably around that. Feels like your moving
TonyToro
Great...keep us posted. Pictures help! Lol
TonyToro
Cool. We run the same weight but call it B stock.
Sarthurs01
Here’s my progress so far. Have the tank mounted fuel line ran, belt on and just about to run wires from the battery back to the motor. Hoping to fire it up this weekend!
Sarthurs01
Still have make the wiring permanent but I got her started up!
fast88pu
If you are pulling with it most clubs will want the battery mounted in a box. You could use a tank under the fender and put battery under hood is an idea.
Sarthurs01
There’s nothing in our clubs rules but I thought about other places so I’m placing on making a cover to go over it for that purpose and look cleaner too.
fast88pu
Could use a boat battery box
Sarthurs01
Little bit more done this weekend
  • Excellent 2
Redneckdavis
So I looked into this for my local club. It says pulley size changes are allowed. And they definitely do not have a mph limit.
baxleyminipullers.net
Sooo. If you didn't have a rule. And you were pulling a 850# tractor. What mph would you?
12.5 Briggs stock. Vertical shaft, true gear box, not variable pulley or hydro. Stock baby tires 18 or so. More tech specs will not do you guys much good. It's not a WH. I don't even know what brand. I'd guess a Rally.
