peter lena 8,752 #1 Posted October 3, 2019 had a chance to get a solid , yet surface rusted dozer blade. got it hone and immediately gave it a chain lube soak down , only wear found was scraper blade , which i quickly turned over. took it apart into the steering quadrant, everything was rust. cleaning scraping and lubing every thing back to life. refitted the lower steering rod with 7/16" flat washers ,and new spring clips. those washers are a tight exact rod size , making for a solid smooth action. best way to work on it is using a milk crate as a stand . and a roller stool. lucas grease on main bolt area and quadrant control, no wear at all on the quadrant angle holes. washer spaced every area along with lubricant , and it was alive with smooth solid movement. this Will work as a back up plow over winter , with the oil spray down preserving its finish , until a fresh paint job in the spring that was one of my jobs today , staying busy, pete 4 Share this post Link to post Share on other sites
Burnerman 758 #2 Posted October 3, 2019 All that and no pictures?😁 2 Share this post Link to post Share on other sites
857 horse 2,581 #3 Posted October 3, 2019 22 minutes ago, Burnerman said: All that and no pictures?😁 PETER,,,,YOU DID A GREAT JOB WITH THE DESCRIPTION,,,,BUT ....THIS CROWD USES ONLY 5 CRAYONS,,,,,AND PICS HELP US SEE,,,,,,ITS NOT OUR FAULT,,,,,,,,WE ARE ALL OLD AND WE USE CROSSING GUARDS .......AND STRUGGLE KEEPING BETWEEN THE LINES......MY SELF INCLUDED,,,,, HOWARD 857HORSE IN VA... 1 4 Share this post Link to post Share on other sites
953 nut 55,885 #4 Posted October 3, 2019 14 minutes ago, 857 horse said: PETER,,,,YOU DID A GREAT JOB WITH THE DESCRIPTION,,,,BUT ....THIS CROWD USES ONLY 5 CRAYONS,,,,,AND PICS HELP US SEE,,,,,,ITS NOT OUR FAULT,,,,,,,,WE ARE ALL OLD AND WE USE CROSSING GUARDS .......AND STRUGGLE KEEPING BETWEEN THE LINES......MY SELF INCLUDED,,,,, HOWARD 857HORSE IN VA... I resemble that remark! 1 2 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #5 Posted October 3, 2019 1 hour ago, Burnerman said: All that and no pictures?😁 1 Share this post Link to post Share on other sites
peter lena 8,752 #6 Posted October 3, 2019 sorry about that , i will see what i can do , pete 2 Share this post Link to post Share on other sites
