scwheelhorse
Deck bearings
scwheelhorse
Can someone please provide me with deck bearing numbers for my 42 in deck on my c120?
peter lena
probably 6203 rs , with 3/4" id measurement , i used timken  oil seals # 473380 on the upper seal end, also used  lucas red and tacky grease to lube those spindles , high 550 temp drop point ensures ,positive lubrication, don,t forget to change the idler bearing , usually a noisy bearing . you can cross chart what i used if you want to w/h parts , or go on amazon or ebay . any other questions just ask ,  the site, pete
scwheelhorse
I read somewhere bearings depend on spindles used. I can post a spindle pic if that helps.
daveoman1966
If your spindle PULLEY uses a Woodruff key, the bearing would be with 3/4" center bore. 106085 (double seal) or 106084 (one seal)  (6203)
If no keyway is used, the spindle shaft is then 5/8" dia...and the bearing ID would also be 5/8".  (#109966)
scwheelhorse
Thank you. I haven't tore it down yet. It's a cold weather project
scwheelhorse
Why is there grease fittings on the mower deck when it uses sealed bearings? Serves no useful purpose.
peter lena
on the lower side of the bearings (   inside spindle  )  you remove the seal so you can refresh the grease in the spindle chamber . i also put in grease between upper and lower bearings , so its off to a good start , ensuring reserve grease to work properly. if you don,t remove the lower inside seal , it will never get a fresh grease refill, pete
Lee1977
The C-120 came with Double D spindles . They could have been upgraded to the later model spindles. I have never replaced any DD spindles bearings. The other two  are 3/4" keyed spindles they use 6203-12 RR bearings ( 40 mm OD  3/4" ID  and 12 mm thick. The metric spindles use 6203  (40 mm OD   17 mm ID  and 12mm thick. The metric spindle will have a 5/8" nut on top.
