Ed Kennell 38,024 #1 Posted October 1, 2019 Had a front row seat this morning. 13 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #2 Posted October 1, 2019 That dont done that method around here. They just put down regular asphalt here. Share this post Link to post Share on other sites
ebinmaine 67,280 #3 Posted October 1, 2019 1 hour ago, The Tool Crib said: regular asphalt Us too. Cool pix Ed. Thanks for sharing. Share this post Link to post Share on other sites
Achto 27,505 #4 Posted October 1, 2019 (edited) 1 hour ago, The Tool Crib said: They just put down regular asphalt here. What they are doing is a seal coat to preserve the asphalt. This is a very common practice in WI. They put tar & pea gravel over the asphalt, it takes a week or two of cars driving on it before it becomes a good solid surface again. Once hardened up, this type of surface provides much better traction in the rain & snow. Edited October 1, 2019 by Achto 3 Share this post Link to post Share on other sites
ebinmaine 67,280 #5 Posted October 1, 2019 1 minute ago, Achto said: What they are doing is a seal coat to preserve the asphalt. This is a very common practice in WI. They put tar & pea gravel over the asphalt, it takes a week or two of cars driving on it before it becomes a good solid surface again. Once hardened up, this type of surface provides much better traction in the rain & snow. I've seen that done somewhere around but I can't remember where. Maine doesn't do anything like that at all. Frost around here can get 5 ft deep in a very cold year and almost none of the roads are well enough prepared for it because of the extreme expense it takes to build a road bed that is that deep. my sister used to live in Wisconsin and I know for a fact that gets colder there than it does here so I don't know how you all keep your roads from flying up in giant piles of cracked asphalt like what happens around here. 1 Share this post Link to post Share on other sites
pfrederi 17,672 #6 Posted October 1, 2019 (edited) The PennDot method also makes for lots of stone chips in your paint and windshield and tar blobs on the rocker panels.... i have lived in several states over the years and PennDot is the absolute worst. They couldn't find their butt with both hands and a road map.... Edited October 1, 2019 by pfrederi 4 1 1 3 Share this post Link to post Share on other sites
Achto 27,505 #7 Posted October 1, 2019 8 minutes ago, ebinmaine said: I don't know how you all keep your roads from flying up in giant piles of cracked asphalt like what happens around here. Something like this is not that uncommon on county, town, & some state roads. Asphalt has lasts from 5 to 10yrs around here, depending on how heavy ( amount of & weight ) the traffic is. Most county and town roads will also have weight restrictions on them in the spring and during wet seasons. My thoughts on pavement " If it ain't concrete, it's your own asphalt " 4 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #8 Posted October 1, 2019 They did or probably still do this in lowa. We had several rural roads in the country. We had lots of chipped windows and chipped paint too. 2 Share this post Link to post Share on other sites
ebinmaine 67,280 #9 Posted October 1, 2019 3 minutes ago, Achto said: restrictions Yep. Same here. The city of Portland doesn't post any roads at all. The rest of the coastal towns post a few. you get inland a little bit and every road that is not a numbered route is shut down for about 2 or 3 months every spring to anyting that is 23000 lbs or even less Share this post Link to post Share on other sites
Ed Kennell 38,024 #10 Posted October 1, 2019 26 minutes ago, pfrederi said: They couldn't find their butt with both hands and a road map.... That's probably what the three guys behind the rear operator are doing. 2 9 Share this post Link to post Share on other sites
ebinmaine 67,280 #11 Posted October 1, 2019 4 minutes ago, Ed Kennell said: That's probably what the three guys behind the rear operator are doing. Now Ed and Paul don't be so silly... you both know as well as I do that's the navigator, first assistant navigator, and second assistant navigator. 1 7 Share this post Link to post Share on other sites
WHX?? 48,788 #12 Posted October 1, 2019 It's the idiots flying down the road at 90 mph on new seal coat that causes the paint chips. 1 Share this post Link to post Share on other sites
Achto 27,505 #13 Posted October 1, 2019 36 minutes ago, ebinmaine said: every road that is not a numbered route is shut down for about 2 or 3 months every spring to anyting that is 23000 lbs or even less Average restriction here is 7 tons per axle. 1 Share this post Link to post Share on other sites
Ed Kennell 38,024 #14 Posted October 1, 2019 4 minutes ago, WHX24 said: It's the idiots flying down the road at 90 mph on new seal coat that causes the paint chips. I don't know Jim. I just got back from the auction....about a 5 mile trip. I stayed under 20 MPH and it sounded like the bottom of the van was being shot blasted. Yeah, I was smart enough to drive Mrs K's Caravan instead of my F-150. She will never notice the tar and chips. 2 8 Share this post Link to post Share on other sites
pfrederi 17,672 #15 Posted October 1, 2019 6 minutes ago, Ed Kennell said: I don't know Jim. I just got back from the auction....about a 5 mile trip. I stayed under 20 MPH and it sounded like the bottom of the van was being shot blasted. Yeah, I was smart enough to drive Mrs K's Caravan instead of my F-150. She will never notice the tar and chips. The stuff PennDot uses flies up at very low speeds. 1 Share this post Link to post Share on other sites
SPINJIM 1,981 #16 Posted October 1, 2019 Half of the gravel ends up on the shoulder of the road, and chips your paint on the way. When you cut your grass along the edge of the road, be careful, because your mower deck will be throwing gravel. It's cheaper for PennDOT, that why they do it. The used that system near me last spring, and it blasted the bottom of my car for two months. Jim 1 Share this post Link to post Share on other sites
Stormin 9,981 #17 Posted October 1, 2019 They do similar over here. Skim of tar then cover with chippings. Finally pass a roller over and leave passing vehicles to do the rest. Oh! Lets not forget the holes and patches they hide. 1 Share this post Link to post Share on other sites
953 nut 55,088 #18 Posted October 1, 2019 3 hours ago, Achto said: Once hardened up, this type of surface provides much better traction in the rain & snow. NCDT did our road with the same system about four years ago and is is holding up well. 1 Share this post Link to post Share on other sites
c-series don 8,666 #19 Posted October 1, 2019 No more oil and stone around here anymore, just resurfacing with asphalt now. As a kid I remember they did oil and sand which worked very well because if the road cracked in the winter from frost the oil and sand mix would become pliable in the summer and mend itself back together. This was done using MC (medium cure) oil. When oil and stone is used it’s usually RC (rapid cure) I used to work for a large paving company where we did roads,driveways, tennis courts etc. A properly installed oil and stone driveway will last many, many years. However I don’t care if it’s asphalt or oil and stone if the base is not properly installed( this is mainly what I did, I was the grader man) it’s not going to last long! 2 1 Share this post Link to post Share on other sites
squonk 41,034 #20 Posted October 1, 2019 (edited) Timely discussion. We have lived in this house for 31 years. The road out front is NY ST. RT. 96 ( also a village street ) When we moved in I called the village street dept about some gravel out front. They said the state was going to come thru and put in curbs, sidewalks and repave. Mind you this was 1988. Since then Main street (also a state highway) has been paved 5 times. The companion street to us to the north (also Rt. 96) was redone with curbs and sidewalks and repaved 2 more times.Our section got nothing but hot patch. In 2010 the state had plans for our section. Replace 2 bridges, rehab a third, and the sidewalks which by disability law they have to have, curbs drainage and repave. We had all kinds of meetings ect. They cut down one of my trees, I moved a fence It was happening!! They started on the bridges and when they got to the third one they find out it needs to be replaced to. So no more work on my end just a patch job where the pavement was shot here and there. Now the fall of 2019. I see paint all on the road. They dig up all the water line connections to check them. We are told they are going to pave at the end of Sept. BUT NO SIDEWALKS,DRAINAGE OR CURBING!!! They start milling the road. They start where they paved in 2010! Tear all that up. They mill the shoulders in front of my house and patch the shoulders??? Finally they mill the road here and tear all that patched shoulders up!!! Now it's Oct. Still waiting for the paving to start. Most of the road is smoother with the milling then it was before! Edited October 1, 2019 by squonk 6 Share this post Link to post Share on other sites
WHX?? 48,788 #21 Posted October 1, 2019 (edited) As long as we're on the topic they got my road past your house done yet Dan? Talk about making a career out of a job! Any chance they hinting for you to move Squonk?? Edited October 1, 2019 by WHX24 3 Share this post Link to post Share on other sites
lynnmor 7,302 #22 Posted October 1, 2019 (edited) Your roads appear a bit better than the ones in Chanceford Township. news Edited October 1, 2019 by lynnmor 2 1 1 Share this post Link to post Share on other sites
Ed Kennell 38,024 #23 Posted October 1, 2019 Hey Lynn, we could fix that "pothole with a couple bags of QPR. 3 Share this post Link to post Share on other sites
JoeM 7,871 #24 Posted October 1, 2019 or.......they tar and chip over the potholes, and three weeks before they tar and chip.......paint lines on the road! Share this post Link to post Share on other sites
Ed Kennell 38,024 #25 Posted October 1, 2019 A little history on my Brownton Road. This is a 2 mile long road that connects state route 74 and Felton road. 2015 tar and chip 2016 paved with 2" asphalt 2017 14- 3' wide cuts from berm to berm to replace the 14 galvanized culverts with plastic 2018 paved with 4" of asphalt 2019 tar and chip 2020 install a sewer or water main down the center of the road This is my prediction based on PENNDOT's previous lack of planning. 3 5 Share this post Link to post Share on other sites
