lynnmor 7,575 #26 Posted November 6, 2019 1 minute ago, Mudrig150 said: The only problem is I made the screws 1/4" long instead of 3/16", so peening them is a lot harder, especially considering they are steel screws... I'm thinking threadlocker is probably the better option. So run the screw thru a nut using washers as needed so that 1/16" sticks out, then grind or file off the excess holding the nut with pliers or a vise. Share this post Link to post Share on other sites
Mudrig150 313 #27 Posted November 6, 2019 What about the problem of them being steel screws? Share this post Link to post Share on other sites
N875ED 98 #28 Posted November 6, 2019 Use a Dremel cut-off wheel to make the tail of the screw the desired length, then stake the remainder. (Don't "kiss" the carb barrel with the wheel, though!) Share this post Link to post Share on other sites
