mrc 809 #1 Posted September 20, 2019 hi men, here is a few pics of my son-in-laws C161 i just fixed. i don't know how many of these cracked/ broken seat support areas i have fixed. certainly a weak link and a bad design of the late C series and 3,4 and 500 series. my hobart welder sure came in handy. thanks to my buddy phil for the pics. mike in mass. 10 3 1 Share this post Link to post Share on other sites
cschannuth 3,816 #2 Posted September 20, 2019 I’d love to see a picture of the entire tractor when it’s put back together. I still have my dad‘s 161 and it is my work horse. 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #3 Posted September 20, 2019 Nice repair job.Good idea to weld in the gussets.I usually only weld in flat stock on top.I'm sure the gussets make a stronger fix.Will remember that for next one I repair. 1 Share this post Link to post Share on other sites
cschannuth 3,816 #4 Posted September 21, 2019 (edited) That looks really great. I’m not a very good welder on the light stuff so I ended up bolting in some angle and it really beefed up my seat on my 161. Edited September 21, 2019 by cschannuth 2 Share this post Link to post Share on other sites
mrc 809 #5 Posted September 26, 2019 cschannuth, your repair looks good. whatever it takes to save these great machines. i'm curious, did you put a blackhood on a regular 'C' series? i thought the dashes on the blackhoods looked different. i only have 1 blackhood. i like it! will try to get a pic when completed. mike in mass. Share this post Link to post Share on other sites
Stike 204 #6 Posted September 26, 2019 Nice fixes on both machines, I need to do the same thing on my c161 though by the look of those pics both of your horses are in better shape than mine. Share this post Link to post Share on other sites
cschannuth 3,816 #7 Posted September 26, 2019 2 hours ago, mrc said: cschannuth, your repair looks good. whatever it takes to save these great machines. i'm curious, did you put a blackhood on a regular 'C' series? i thought the dashes on the blackhoods looked different. i only have 1 blackhood. i like it! will try to get a pic when completed. mike in mass. Mine is a 1978 model so it may have changed on later blackhoods. My dad bought this when it was one year old from our neighbor and it originally had the plastic seat pan which the neighbor had already broken so my dad installed a metal pan. Share this post Link to post Share on other sites
mrc 809 #8 Posted October 1, 2019 hello cschannuth, what size angle did you use? 2x2x1/8"??? thanks mike in mass. Share this post Link to post Share on other sites
WildmanC120 613 #9 Posted October 1, 2019 On 9/26/2019 at 3:02 PM, mrc said: cschannuth, your repair looks good. whatever it takes to save these great machines. i'm curious, did you put a blackhood on a regular 'C' series? i thought the dashes on the blackhoods looked different. i only have 1 blackhood. i like it! will try to get a pic when completed. mike in mass. I can't tell but this is probably a twin Briggs. The hood is fiberglass while the other real black good models are metal. So essentially it's pretty much a c series with a black fiberglass good. Transitional year. Share this post Link to post Share on other sites
peter lena 8,556 #10 Posted October 1, 2019 that angle steel redo , makes the most sense, pete Share this post Link to post Share on other sites
cschannuth 3,816 #11 Posted October 1, 2019 1 hour ago, mrc said: hello cschannuth, what size angle did you use? 2x2x1/8"??? thanks mike in mass. Yessir Share this post Link to post Share on other sites
ericj 1,578 #12 Posted October 2, 2019 (edited) I was told by Ed Cole, the Toro rep, at the big show one year, that Wheel Horse was testing the new Kohler KT17 for durability and reliability testing and it failed, as John Deere found out, so for shits and giggles they threw the Briggs twin up and tested it. Well surprise surprise the Briggs passed. this caught wheel horse with not enough time for planning and caused wheel horse to rush to get the motor on a tractor. I'm guessing the motor wouldn't fit in a 78 C series normal hood. They quickly designed the black hood, from fiberglass to fit the C series dash, thus the black hood was born. They used the C161 TWIN for 78 and 79 before the redesign in 1980 into the C1x5 series tractor. eric j Edited October 2, 2019 by ericj Share this post Link to post Share on other sites
cschannuth 3,816 #13 Posted October 2, 2019 8 hours ago, ericj said: I was told by Ed Cole, the Toro rep, at the big show one year, that Wheel Horse was testing the new Kohler KT17 for durability and reliability testing and it failed, as John Deere found out, so for shits and giggles they threw the Briggs tins up and tested it. Well surprise surprise the Briggs passed. this caught wheel horse with not enough time for planning and caused wheel horse to rush to get the motor on a tractor. I'm guessing the motor wouldn't fit in a 78 C series normal hood. They quickly designed the black hood, from fiberglass to fit the C series dash, thus the black hood was born. They used the C161 TWIN for 78 and 79 before the redesign in 1980 into the C1x5 series tractor. eric j That is my understanding as well. That twin Briggs is still all original and runs like a top over 40 years later. Share this post Link to post Share on other sites
ohiofarmer 3,265 #14 Posted October 2, 2019 (edited) I am not sure, but the weak cantilever seat in combination with the thin tunnel may have been the same one the 520 Toro/wheelhorse used later. Anyway, the seat hardware from a 520 will fit on my c-141. i am pretty sure the rear frame tunnel is made of thinner steel on the 4 and 500 series. That design nearly dumped me off the 520 when i was mowing a side ditch in the area around a 4' deep catch basin. I am always on the look out for discarded bed frames as a source for angle iron. That stuff is wicked strong for its size and weight and has a very sharp bend radius. I am not the only one to discover this. Old crusty repair guys use college towns as a source for bed frames as the graduating students throw tons of beds away every spring..... So if you guys do any amount of mowing on side slopes, take the time to remove the seat pan and inspect the frame beneath. Edited October 2, 2019 by ohiofarmer 1 Share this post Link to post Share on other sites
mrc 809 #15 Posted October 21, 2019 cscannuth, here are a few pics of the tractor all back together. also included are a couple pics of the zach kerber solid motor mounts installed. regards mike in mass. 2 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,009 #16 Posted October 21, 2019 mrc - Is your tractor a 1978 or 1979 model? Have been watching for the locations of the tractor ID plates these two years. Garry Share this post Link to post Share on other sites
mrc 809 #17 Posted October 21, 2019 garry, the tractor is now back at my son-in-laws house which is 45 minutes from me. i do not know the year exactly. how do i tell what year? regards mike in mass. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,009 #18 Posted October 22, 2019 The model number on the ID plate will start with 81 or 91 for 1978 and 1979. These are usually printed with the remainder stamped into the plate. Serial number will follow on the top line. The bottom line will have a 4-digit Julian build date. Many 1978 models have the ID plate facing the opposite direction down beside the steering fan gear on the front of the left side hoodstand. Trying to determine when the ID plate location changed. Garry Share this post Link to post Share on other sites
