Kstu64
Interchangeable attachments
Kstu64
I have a wheel horse 312-8 model number 73362 wiill a snowblower model number 79366 fit on my tractor?
gwest_ca
No it will not fit. It is 44" 2-stage for the 5xi series of tractors.
You need one similar to this which are 42" single-stage and much lighter.
Here is a list that will fit
Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar.
1973-74 model 6-6212 plus 6-9113
1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate)
1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank)
1976 model 6-6215 - This one -
1976 model 66-42ST01 - and this one are likely identical. The model number format changed.
1977 model 76-42ST01 - This one
1978 model 86-42ST01 - and this one
1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year.
1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute)
1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels)
1983 model 06-42ST03 - (First model to use skids)
1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft)
1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft)
1990 model 06-42ST06
1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers)
1993-2001 model 79360
2002-2007 model 79362
Garry
The Tuul Crib
:text-welcomeconfetti:to :rs:
@Kstu64 !! :wwp:
Achto
:WRS:
  • Similar Content
    • Bill D
      By Bill D
      Sometimes people ask me to fix equipment for them.  I knew it was a snowblower, but I thought it was newer.  I not sure what I'm going to do with it.  Needs a lot of work.
    • shallowwatersailor
      By shallowwatersailor
      Not that my Ariens walk-behind snowblower let me down, but I really had to work hard today to move the snow off the last remaining driveway belonging to a neighbor. This is the one that I always have problems to begin with due to the grade it has. I almost gave up due to lack of traction. The depth of the snow was still about 24" but had settled almost a foot so was very dense. The Ariens kept climbing while moving forward and then losing traction . This may have been a rare occasion and maybe chains would have helped but I'm curious
      I have already spoken to 3Six about his but wondering if other members have any thoughts or experience?
