bottjernat1 2,196 #26 Posted September 17, 2019 On 9/15/2019 at 4:51 PM, ebinmaine said: See the picture. Also, the manual states I need to swap crank gears from one crank to another so that they match the camshaft gear. Is that actually important? if you ever need a NOS crank let me know. i have 10 NOS tecumseh crank shafts! I have them listed on facebook market place. Selling all 10 dirt cheap 1 Share this post Link to post Share on other sites
CasualObserver 3,411 #27 Posted September 17, 2019 On 9/15/2019 at 5:42 PM, ebinmaine said: What size hammah?? This should do. 3 Share this post Link to post Share on other sites
ebinmaine 75,712 #28 Posted September 17, 2019 2 minutes ago, CasualObserver said: This should do. I'm a fairly decent sized dude but that might be even a LITTLE on the outside of my capabilities...... 3 Share this post Link to post Share on other sites
ebinmaine 75,712 #29 Posted September 17, 2019 4 hours ago, The Tool Crib said: Norm speaks the truth I still don't have enough ! that's a good assortment Randy. I don't think I need quite that many bearing removal tools...... Share this post Link to post Share on other sites
The Tuul Crib 7,340 #30 Posted September 17, 2019 47 minutes ago, ebinmaine said: that's a good assortment Randy. I don't think I need quite that many bearing removal tools...... Ya never know!! Share this post Link to post Share on other sites
pfrederi 19,245 #31 Posted September 17, 2019 2 hours ago, The Tool Crib said: Ya never know!! Most of my collection 3 Share this post Link to post Share on other sites
RandyLittrell 3,942 #32 Posted September 17, 2019 Any reason why you couldn't wrap a cold wet towel around the end of the crank and heat the bearing to get it off? I usually use my BBQ grill to heat bearings and such to put them on, can't see why it would hurt to heat it to remove it. Randy Share this post Link to post Share on other sites
bc.gold 3,406 #33 Posted September 17, 2019 On 9/15/2019 at 6:41 PM, adsm08 said: https://www.eastwood.com/5-ton-bar-type-puller-bearing-set-atd-tools.html?SRCCODE=PLA00020&msclkid=ab049e62993818480493c31c552c2556 This will remove it, it will not install it. Yea that one, bearing splitter. Share this post Link to post Share on other sites
ebinmaine 75,712 #34 Posted September 17, 2019 51 minutes ago, RandyLittrell said: Any reason why you couldn't wrap a cold wet towel around the end of the crank and heat the bearing to get it off? I usually use my BBQ grill to heat bearings and such to put them on, can't see why it would hurt to heat it to remove it. Randy Y'a got me Randy. ?? It'll be a few days before I get a chance to try this now. Anyone else ever try it? 1 Share this post Link to post Share on other sites
adsm08 3,853 #35 Posted September 18, 2019 (edited) 6 hours ago, pfrederi said: Most of my collection Psssh, armature hour. I have the red case in the middle, both those hand pullers, a slide hammer, an assortment of two and three jaw pullers, this kit: and this guy: I got tired of how long it took to pump the jack out to full extension and retrofit it with a hydraulic/pneumatic unit, so I can run it out close to my work piece quickly and then use the handle for delicate work. Oh, and the oxy/acetylene torch in the corner for when I'm done messing around. Edited September 18, 2019 by adsm08 1 Share this post Link to post Share on other sites
squonk 44,859 #36 Posted September 18, 2019 19 hours ago, CasualObserver said: This should do. The only tool needed for a Tecky! Share this post Link to post Share on other sites
AMC RULES 37,250 #37 Posted September 18, 2019 ...and there's the tool you need to keep away from your Techy. 1 Share this post Link to post Share on other sites
ebinmaine 75,712 #38 Posted September 18, 2019 1 hour ago, AMC RULES said: ...and there's the tool you need to keep away from your Techy. Or use it to just finished breaking the darn thing...... Share this post Link to post Share on other sites
Thatoneguy 197 #39 Posted July 21, 2023 On 9/15/2019 at 8:25 PM, ZXT said: ^ that! I pulled the Tecumseh off of mine because the starter died. That's all the reason I needed. I'd probably give the thing to somebody if they were close. I am not too far!! 1 Share this post Link to post Share on other sites
Thatoneguy 197 #40 Posted July 21, 2023 On 9/17/2019 at 6:49 AM, bottjernat1 said: if you ever need a NOS crank let me know. i have 10 NOS tecumseh crank shafts! I have them listed on facebook market place. Selling all 10 dirt cheap Do you still have any crank shafts available? Share this post Link to post Share on other sites
