The Tuul Crib 7,338 #1 Posted September 14, 2019 So I'm sitting here looking at the manual of the wiring on a 312-8 and trying to figure out where the regulator is. Can someone point this out for me because I'm missing it. Share this post Link to post Share on other sites
adsm08 2,384 #2 Posted September 14, 2019 I don't see the regulator or the generator on that page, is there another page for that tractor? Share this post Link to post Share on other sites
The Tuul Crib 7,338 #3 Posted September 14, 2019 This is the wiring diagram for the 312-8 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #4 Posted September 14, 2019 No regulator. Just a diode the rectify a 3 amp stator to charge the battery and a 2nd stator that powers the lights only with AC current. Garry 4 1 Share this post Link to post Share on other sites
pfrederi 18,180 #5 Posted September 14, 2019 Welcome to when WH went CHEAP!!!! 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #6 Posted September 14, 2019 Wow Share this post Link to post Share on other sites
clueless 3,074 #7 Posted September 15, 2019 My 312-8 with the mag engine has a 15amp regulator on the front of the engine shroud. I thought the 310 and 308 were the only ones with the 3amp, could be wrong, it's been known to happen. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #8 Posted September 16, 2019 my 414-8 mag has one mounted to the front of the shroud. This the most reliable tractor! Share this post Link to post Share on other sites
The Tuul Crib 7,338 #9 Posted September 16, 2019 Is it possible to add a 15 amp stater and a regulator to the system ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #10 Posted September 16, 2019 Sure you can. This is a K301 or M12? Garry 1 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #11 Posted September 17, 2019 10 hours ago, gwest_ca said: Sure you can. This is a K301 or M12? Garry Its a k 301 Share this post Link to post Share on other sites
pfrederi 18,180 #12 Posted September 17, 2019 2 hours ago, The Tool Crib said: Its a k 301 Used stators are on ebay a lot. You will need the regulator and have to rewire your head lights. Easy game. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #13 Posted September 17, 2019 59 minutes ago, pfrederi said: Used stators are on ebay a lot. You will need the regulator and have to rewire your head lights. Easy game. Im picking up three motors today . Hopefully one of them are good. 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #14 Posted September 17, 2019 I would do as pfrederi suggested, order a simple Charging coil and upgrade the actual system, the regulators until 15A also available on same source. The charging coils have two wires, where the regulator will be connected (ac in) and the Output can be simple attached to Battery. I would insert a 20A fuse, in case if Regulator blows. The Lights are on one side connected to Ground and other side simply rewired after switch with a fuse to + on battery. easy to do, and most benefit by less work. 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #15 Posted September 17, 2019 5 hours ago, The Tool Crib said: Im picking up three motors today . Hopefully one of them are good. Like the old meaning better to have than to need... 1 Share this post Link to post Share on other sites
Hardesty435 1 #16 Posted October 12, 2020 I have two wheel horse 312-8 models, one is a 1988 model with the magnum engine, the other is a 1985 with the K301 engine. The magnum engine has the 3 wire voltage regulator mounted on the front motor shroud, the non-magnum does not, when I put my volt meter in dc volts and check the battery cables with it running, no battery, it is showing over 200 volts and the wiring is getting hot, what is suppose to regulate my voltage, I thought that I read that all models didn't have regulators, could the stator be bad and sending to much current??? Share this post Link to post Share on other sites
Handy Don 13,084 #17 Posted October 12, 2020 Does “no battery” mean you’ve disconnected it with the engine running and are then taking measurements? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #18 Posted October 12, 2020 1985 and 1986 312 models with the K301 has 2 stators. One provides AC current directly to the light circuit. The DC bulbs work fine with AC voltage. The 2nd stator has a diode at it's output that rectifies the AC current to DC to charge the battery. It is not regulated as the 3 amp output theoretically will not overcharge the battery. Most models have a decal on them warning not to run without a battery connected. The possible 200 volts is the reason why. A digital voltmeter is capable of picking them up but so will other 12 volt components in the system and they may expire. An analog voltmeter won't display them because they react slower but they are still there. Garry 1 Share this post Link to post Share on other sites
Hardesty435 1 #19 Posted October 12, 2020 12 hours ago, gwest_ca said: 1985 and 1986 312 models with the K301 has 2 stators. One provides AC current directly to the light circuit. The DC bulbs work fine with AC voltage. The 2nd stator has a diode at it's output that rectifies the AC current to DC to charge the battery. It is not regulated as the 3 amp output theoretically will not overcharge the battery. Most models have a decal on them warning not to run without a battery connected. The possible 200 volts is the reason why. A digital voltmeter is capable of picking them up but so will other 12 volt components in the system and they may expire. An analog voltmeter won't display them because they react slower but they are still there. Garry Well here is the problem, when the battery was in it, the wiring harness next to the fuses was getting extremely hot, to the point it was melting the fuse, when i unhooked the battery, the engine ran smoother, like it was laboring when hooked up to the battery, and the fuse didn't seem to get as hot, where can I locate the stators, and is there a way to check them? thanks in advance 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #20 Posted October 13, 2020 That is strange. Battery negative does ground to the chassis? Is the correct stator lead with the diode near the connector connected to the white wire? Garry Share this post Link to post Share on other sites
Handy Don 13,084 #21 Posted October 13, 2020 The troubleshooting guide is terrific. Is that available for download @gwest_ca? Share this post Link to post Share on other sites
953 nut 56,741 #22 Posted October 13, 2020 12 hours ago, Hardesty435 said: Well here is the problem, when the battery was in it, the wiring harness next to the fuses was getting extremely hot, to the point it was melting the fuse, when i unhooked the battery, the engine ran smoother, like it was laboring when hooked up to the battery, and the fuse didn't seem to get as hot, where can I locate the stators, and is there a way to check them? thanks in advance Looking at the drawings that Garry @gwest_ca provided I would start with the fuse and the fuse holder, If one or both are badly corroded they will act like a low resistance voltage drop resistor and generate a lot of heat. Here is an explanation that @Save Old Iron posted a few years ago. Think about it - if you forced a sudden surge of lets say 35 amps thru a 30 amp fuse - the fuse internal element slowly "melts" - usually within a few seconds - you see a melted wire in the fuse body and the fuse body and leads remain looking like they originally did ( give or take a little). If you dead shorted the battery thru the fuse to the chassis, you may blacken the inside of the fuse but the fusible element melts long before you have a chance to cook the entire fuse body like in your picture. Same idea for the white plastic engine harness connector - the brown discoloration is from cooked plastic - where is the heat coming from ?? The "Molex" style connectors used in this tractor series are in a harsh, corrosive environment. Vibration causes the connections to loosen - corrosion starts within the metal terminals and a voltage drop develops across the corrosion. If you have a 10 amp current flowing across a 1 ohm resistance (contact corrosion) the electronics formula to calculate power = current squared times resistance so 10 amps x 10amps x 1 ohm resistance = 100 watts !! 100 watts of connector heating is the same as laying a 100 watt soldering iron on the connector. 1 Share this post Link to post Share on other sites
squonk 41,936 #23 Posted October 13, 2020 What kind of fuse holder do you have on it. does it look like this? If so throw it as far as you can and get something like this: Those round fuse holders are not waterproof and as they age the internal spring corrodes and weakens causing heat , bad connections and all sorts of weird happenings. 1 1 Share this post Link to post Share on other sites
Hardesty435 1 #24 Posted October 14, 2020 12 hours ago, squonk said: What kind of fuse holder do you have on it. does it look like this? If so throw it as far as you can and get something like this: Those round fuse holders are not waterproof and as they age the internal spring corrodes and weakens causing heat , bad connections and all sorts of weird happenings. it is like the bottom holder Share this post Link to post Share on other sites
Hardesty435 1 #25 Posted October 14, 2020 14 hours ago, 953 nut said: Looking at the drawings that Garry @gwest_ca provided I would start with the fuse and the fuse holder, If one or both are badly corroded they will act like a low resistance voltage drop resistor and generate a lot of heat. Here is an explanation that @Save Old Iron posted a few years ago. Think about it - if you forced a sudden surge of lets say 35 amps thru a 30 amp fuse - the fuse internal element slowly "melts" - usually within a few seconds - you see a melted wire in the fuse body and the fuse body and leads remain looking like they originally did ( give or take a little). If you dead shorted the battery thru the fuse to the chassis, you may blacken the inside of the fuse but the fusible element melts long before you have a chance to cook the entire fuse body like in your picture. Same idea for the white plastic engine harness connector - the brown discoloration is from cooked plastic - where is the heat coming from ?? The "Molex" style connectors used in this tractor series are in a harsh, corrosive environment. Vibration causes the connections to loosen - corrosion starts within the metal terminals and a voltage drop develops across the corrosion. If you have a 10 amp current flowing across a 1 ohm resistance (contact corrosion) the electronics formula to calculate power = current squared times resistance so 10 amps x 10amps x 1 ohm resistance = 100 watts !! 100 watts of connector heating is the same as laying a 100 watt soldering iron on the connector. thanks, I will check the fuse holders for corrosion. 1 Share this post Link to post Share on other sites
