TDF5G 2,069 #1 Posted September 5, 2019 (edited) My Dad's 314-8 has the worn out shock/strut on the clutch pedal. The strut is expensive to replace and requires some tear down to access it. I found on the forum that I could add the 108035 spring like the older tractors to solve the problem. I dreamed up this homemade tool one evening to install the new spring. It may be old news to some of y'all that may have already thought of this. But it worked like a charm. I removed the left rear wheel for better access. Just an eye hook and a piece of dowel rod. Edited September 5, 2019 by TDF5G 5 4 1 Share this post Link to post Share on other sites
ebinmaine 68,507 #2 Posted September 5, 2019 That ... is a great idea. I use an old school drum brake spring installation tool. Sometimes have to try twice but it always works. 2 Share this post Link to post Share on other sites
TDF5G 2,069 #3 Posted September 5, 2019 1 minute ago, ebinmaine said: That ... is a great idea. I use an old school drum brake spring installation tool. Sometimes have to try twice but it always works. I was kinda proud of myself. Thank you. We talked about trying a automotive brake spring tool, but I couldn't see where there was a place to grab on to with it. I never did try it though. When the spring arrived, my first thought was, "This spring is so stiff, I'll never get it stretched on there." The eye part of the hook could be cut open a little bit. I will do that before I use it again. The most difficult part was hooking the front of the spring in the lever hole first, where the rear hook is oriented properly. 1 Share this post Link to post Share on other sites
ebinmaine 68,507 #4 Posted September 5, 2019 Been a few months since I've messed with one of those but I think the orientation may have been my issue now that you say that. I assume there must be different sizes of those tools considering that there are different sizes of drum brakes. The one I have is a Lisle brand. I'd have bought it to do between 10 and 13 inch diameter brakes. Like you, I catch the front hook first and then I use the cast iron fin where the spring is going to be put into as my grabbing point. . 1 Share this post Link to post Share on other sites
oliver2-44 9,875 #5 Posted September 5, 2019 Great Idea 1 Share this post Link to post Share on other sites
TDF5G 2,069 #6 Posted September 5, 2019 26 minutes ago, oliver2-44 said: Great Idea Thank you. Share this post Link to post Share on other sites
953 nut 55,904 #7 Posted September 5, 2019 I have one like the one below, but I'm all for home made low dollar tools that work. 3 Share this post Link to post Share on other sites
TDF5G 2,069 #8 Posted September 6, 2019 I wasn't aware there is a tool for this. But I'm not surprised. Share this post Link to post Share on other sites
adsm08 2,192 #9 Posted September 7, 2019 A lot of parts stores sell a tool like this for $5-10. 1 Share this post Link to post Share on other sites
AMC RULES 37,134 #10 Posted September 7, 2019 Nice way to save a buck or ten! 1 Share this post Link to post Share on other sites
tunahead72 2,439 #11 Posted September 7, 2019 Thanks for all the ideas guys. I always struggle with springs, and these tools are all certainly a lot more effective and safe than anything I've ever tried! 1 Share this post Link to post Share on other sites
