Nukes6689 1 #1 Posted September 3, 2019 Push or pull I am thinking about fabricating one. Just needing so guide lines on size and the best way to lift it and maybe some down pressure. It does not look that difficult but I bet that it can be done very wrong. Share this post Link to post Share on other sites
oliver2-44 9,695 #2 Posted September 3, 2019 The larger WH designed mid-mount grader blades were pushed. They attached to the rear axle with the axle bracket. Some of the smaller blades were pulled. Look in the "Manuals" section and you will find manuels/pictures of some of them. Share this post Link to post Share on other sites
ebinmaine 67,285 #3 Posted September 3, 2019 6 hours ago, Nukes6689 said: needing so guide lines on size and the best way to lift it and maybe some down pressure Here's a thread I did with pics and measurements of a pull type. They lift with the left handle. Down pressure is done by your own hand or extra weight added to the blade. Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #4 Posted September 3, 2019 9 hours ago, ebinmaine said: Here's a thread I did with pics and measurements of a pull type. They lift with the left handle. Down pressure is done by your own hand or extra weight added to the blade. On a hydro unit such as the 520 there is down pressure.. 1 Share this post Link to post Share on other sites
