trailhopper
60" Mower Blades
trailhopper
Are the Toro OE blades the best to use on the 520H/60" deck? Any other suggestions that work well? I have some Gator blades on it now, that came with the deck. They did OK, but they're worn out. Unfortunately, I use this mower to mow a property that I visit every month or so. The grass is typically tall. Thanks.
-Scott
Skipper
The OE ones give a really good airflow to clear the grass out of the deck. I have tried aftermarket ones, also the gators. The gators were the worst, and I have so far not found any blade that is equal to the OE, but I sure would like to know too, if someone should know where to get 1:1 copies :-)
trailhopper
23 minutes ago, gwest_ca said:
Toro blade 112947 (x3) (5/8" round hole) and Oregon Gator
https://www.rcpw.com/search/?quest=112947
Toro blade for wet grass 78-2480 replaced by 78-2480-03 (x3)
https://www.rcpw.com/search/?quest=78-2480-03
Garry
Looks like the Toro OE blades are preferred. Have you used the "wet grass" blades?
-Scott
gwest_ca
No I have not - no 60" deck.
Ran across the wet grass blade part number somewhere so recorded it. Have no idea how they are different. Must be gold plated to prevent corrosion @ $77-$87 each.
Garry
