WHX?? 50,615 #1801 Posted September 7, 2023 (edited) OK since there is a bit of chatter here thought I would read to ketchup. Turns out I took it in the Heinze... Just a bunch of palaver and nonsense about chainsaws & spiders... oh well. Old saying EB in your defence... Rome wasn't built in a day... Edited September 7, 2023 by WHX?? Speeling 5 Share this post Link to post Share on other sites
Pullstart 64,435 #1802 Posted September 7, 2023 57 minutes ago, ebinmaine said: The direction the engine faces is less important to me than good function. How would I see how an XI drive works? Something like this…. But you could stick it on the right side vertically. 2 Share this post Link to post Share on other sites
WHX?? 50,615 #1803 Posted September 7, 2023 3 minutes ago, Pullstart said: Something like this…. But you could stick it on the right side vertically. Can we apply that to racing mowers? 1 Share this post Link to post Share on other sites
Achto 28,682 #1804 Posted September 7, 2023 @ebinmaine & @Pullstart If this was rated for higher horse power, it may be useful. https://www.surpluscenter.com/Power-Transmission/Gear-Reducers-Gearboxes/Gearboxes/10-HP-1-1-RA-3600-RPM-Same-Rotation-In-Out-Peerless-1000-014-D-Gearbox-13-1616-A.axd 3 Share this post Link to post Share on other sites
ebinmaine 70,537 #1805 Posted September 7, 2023 6 hours ago, Achto said: @ebinmaine & @Pullstart If this was rated for higher horse power, it may be useful. https://www.surpluscenter.com/Power-Transmission/Gear-Reducers-Gearboxes/Gearboxes/10-HP-1-1-RA-3600-RPM-Same-Rotation-In-Out-Peerless-1000-014-D-Gearbox-13-1616-A.axd Dan I do have a Peerless 90⁰ gearbox out of a Toro Grounds Master but I think it's too rusted to save. I looked at the 32 HP rated units on Surplus Center. They're max input is 1800 RPM. I could solve that by using a drive/driven pulley of the right ratio both in and out of the box. Share this post Link to post Share on other sites
ebinmaine 70,537 #1806 Posted September 7, 2023 Found this Porsche pic 2 2 Share this post Link to post Share on other sites
Pullstart 64,435 #1807 Posted September 7, 2023 See, there you go! Share this post Link to post Share on other sites
ebinmaine 70,537 #1808 Posted September 7, 2023 In that video clip above I would have to reverse the belt for the correct orientation Share this post Link to post Share on other sites
squonk 42,450 #1809 Posted September 7, 2023 13 hours ago, WHX?? said: Old saying EB in your defence... Rome wasn't built in a day... The chunnel took 6 years to build. We are now on year #4 on Colossus! 1 2 Share this post Link to post Share on other sites
ebinmaine 70,537 #1810 Posted September 7, 2023 20 minutes ago, squonk said: The chunnel took 6 years to build. We are now on year #4 on Colossus! So I'm still 2 ahead!! 1 Share this post Link to post Share on other sites
ebinmaine 70,537 #1811 Posted September 13, 2023 I'm thinking something like this could be a good bet to transfer the direction of rotation. 1 Share this post Link to post Share on other sites
lynnmor 7,553 #1812 Posted September 13, 2023 1 hour ago, ebinmaine said: I'm thinking something like this could be a good bet to transfer the direction of rotation. Do some more research on that part, my guess is that it will get hotteranhell after extended use. 1 Share this post Link to post Share on other sites
ebinmaine 70,537 #1813 Posted September 13, 2023 1 minute ago, lynnmor said: Do some more research on that part, my guess is that it will get hotteranhell after extended use. That's a legitimate possibility. The duty cycle on a lot of mower gearboxes is not meant to be 100%. I may use pulleys to slow it down to 1800/2200 RPM internally. Share this post Link to post Share on other sites
SylvanLakeWH 27,380 #1814 Posted September 13, 2023 Just wondering if you are overthinking this engine orientation thing... ? 1 Share this post Link to post Share on other sites
ebinmaine 70,537 #1815 Posted September 13, 2023 3 minutes ago, SylvanLakeWH said: Just wondering if you are overthinking this engine orientation thing... ? I over think pretty much everything so the short answer is yes. That said... This engine is BIG. It's several inches wider taller and longer than anything ever put in a Wheelhorse. It's HEAVY. This beast is full cast iron and steel except the cylinder heads and carburetor. If one were to install this engine with the pulley system in a lined up position the static weight center would be several inches on the OUTSIDE of the left hand frame rail. And I will be able to USE this machine. In the woods. Tilted. So it really needs to be balanced right. With the knowledge base i have that leaves me with two possibilities. Utilize some sort of right angle power transmission. Offset the engine 6 or 8 inches to the right and use pillow blocks and an idler shaft with two pulleys to realign the belt to the transmission. 2 Share this post Link to post Share on other sites
Handy Don 13,333 #1816 Posted September 13, 2023 6 minutes ago, ebinmaine said: Offset the engine 6 or 8 inches to the right and use pillow blocks and an idler shaft with two pulleys to realign the belt to the transmission. This. My instinct would be to center the mass of the engine and use a jackshaft to get the final drive alignment you want. i’d also look at having the main (or secondary?) PTO come off the jackshaft, if that made things more compact or convenient. 2 Share this post Link to post Share on other sites
ebinmaine 70,537 #1817 Posted September 13, 2023 23 minutes ago, Handy Don said: This. My instinct would be to center the mass of the engine and use a jackshaft to get the final drive alignment you want. i’d also look at having the main (or secondary?) PTO come off the jackshaft, if that made things more compact or convenient. I'll have to look at getting a couple of double pulleys included in that in case I want to use one to drive something later. On my cross shaft now... How does one figure out the diameter needed for the right strength? This one's going to have a fair amount of leverage on one end and it would be handy if it was the same size as the engine crankshaft for pulley swapping reasons later. I think that's around 1 and 1/8 or 1 1/4. Share this post Link to post Share on other sites
Handy Don 13,333 #1818 Posted September 13, 2023 (edited) 5 minutes ago, ebinmaine said: On my cross shaft now... How does one figure out the diameter needed for the right strength? This one's going to have a fair amount of leverage on one end and it would be handy if it was the same size as the engine crankshaft for pulley swapping reasons later. I think that's around 1 and 1/8 or 1 1/4. I agree with close to crankshaft sizing if your intent is to transmit ALL of the engine's power through that shaft at something close to the engine’s RPM. If the RPMs will be noticeably lower, then go to the larger diameter (and vice versa). Edited September 13, 2023 by Handy Don 1 Share this post Link to post Share on other sites
kpinnc 13,656 #1819 Posted September 13, 2023 2 hours ago, ebinmaine said: I over think pretty much everything so the short answer is yes. I should have a t-shirt with that printed on it... ...as a warning label! 4 Share this post Link to post Share on other sites
8ntruck 7,368 #1820 Posted September 13, 2023 1 hour ago, Handy Don said: I agree with close to crankshaft sizing if your intent is to transmit ALL of the engine's power through that shaft at something close to the engine’s RPM. If the RPMs will be noticeably lower, then go to the larger diameter (and vice versa). You will want to pay attention to the bearing location on the shaft, too. Be best to keep the bearings near the pulleys and not have several inches of cantilevered shaft between a pulley and a bearing. 1 Share this post Link to post Share on other sites
ebinmaine 70,537 #1821 Posted September 13, 2023 1 minute ago, 8ntruck said: You will want to pay attention to the bearing location on the shaft, too. Be best to keep the bearings near the pulleys and not have several inches of cantilevered shaft between a pulley and a bearing. Understood and agreed but I won't have a choice on one end. The inner pulley that feeds the transmission will be right beside a pillow block but the outer one that is driven by the engine will be More than 6" out. Share this post Link to post Share on other sites
JCM 10,011 #1822 Posted September 13, 2023 I'm getting dizzy reading all of this.It may be time for a night cap even though it's still light out. I'm going to find you a C-195 where you are a fan of Kohlers and large diameter rear tires and get out in your property and start enjoying your land instead of working on WH's. Enjoy life, it's way to short. There, now I don't need that nightcap. Thanks for letting me vent . Get going on that F-250 Brother 2 1 1 Share this post Link to post Share on other sites
ebinmaine 70,537 #1823 Posted September 13, 2023 3 minutes ago, JCM said: I'm going to find you a C-195 where you are a fan of Kohlers and large diameter rear tires and get out in your property and start enjoying your land instead of working on WH's. Enjoy life, I'll take BOTH of those. A Super C would be cool. And.... I LOVE working on Wheelhorses. I know I know. I'm a bit twisted. 🤪 1 3 Share this post Link to post Share on other sites
Handy Don 13,333 #1824 Posted September 13, 2023 1 hour ago, ebinmaine said: Understood and agreed but I won't have a choice on one end. The inner pulley that feeds the transmission will be right beside a pillow block but the outer one that is driven by the engine will be More than 6" out. You’ll want to think about extending a solid brace off the frame to get that bearing closer to the pulley. Even a 1” shaft will have some deflection at 6” with 20+HP working on it via a pulley. And deflection will introduce vibration. And....bad. 2 Share this post Link to post Share on other sites
ebinmaine 70,537 #1825 Posted September 13, 2023 1 hour ago, Handy Don said: You’ll want to think about extending a solid brace off the frame to get that bearing closer to the pulley. Even a 1” shaft will have some deflection at 6” with 20+HP working on it via a pulley. And deflection will introduce vibration. And....bad. Agreed. I'll take some measurements and see what we can come up with. Share this post Link to post Share on other sites
