953 nut 57,513 #101 Posted September 11, 2019 On 9/9/2019 at 6:36 AM, ebinmaine said: Might sound like a silly question but I've never actually seen one. Do those bolt up to a regular 8-speed? A determined individual with a welder and a drill can make anything fit! 2 3 Share this post Link to post Share on other sites
LengerichKA88 1,883 #102 Posted September 14, 2019 On 9/11/2019 at 12:00 AM, oliver2-44 said: Why not add a "spare tire" to your design, kind of like the old cars that had the spare mounted on the front running board. Then you can fill and adjust the spare weight as desired. Picturing that in my head, I like the idea for looks alone! 1 Share this post Link to post Share on other sites
ebinmaine 70,339 #103 Posted September 15, 2019 8 hours ago, LengerichKA88 said: Picturing that in my head, I like the idea for looks alone! Certainly would be interesting.... Share this post Link to post Share on other sites
Lee1977 6,992 #104 Posted September 15, 2019 That tractor frame you are using is it a long frame or short frame? Share this post Link to post Share on other sites
ebinmaine 70,339 #105 Posted September 15, 2019 Long frame from a 3,4,500 series. It has the second set of step support bars. Share this post Link to post Share on other sites
Justice77 163 #106 Posted September 21, 2019 Looks like a fun project you have there. I'll be following along! 1 Share this post Link to post Share on other sites
953 nut 57,513 #107 Posted September 21, 2019 Just found a bit of inspiration for you! 8 Share this post Link to post Share on other sites
troutbum70 857 #108 Posted September 21, 2019 That's a rat rod 1 Share this post Link to post Share on other sites
ebinmaine 70,339 #109 Posted September 21, 2019 Been too busy with work the last few days to do anything but move the project around in the shed a couple times. I did find a spacer for the length to go between the frame and transmission. Our fabrication friend is getting me a piece of 6 x 6 tube steel cut to 7" length. I'll cap one side and leave the hole facing downward to access the bolts. Share this post Link to post Share on other sites
Tractorhead 9,087 #110 Posted September 21, 2019 Still Following the Project. Don‘t forget nothing is happen, without Pic‘s....😎 👍😉 1 Share this post Link to post Share on other sites
wallfish 17,393 #111 Posted September 21, 2019 Concerning the centering of the engine weight over the frame, you could use a jack shaft which would allow the engine to slide lateral on the frame. The jack will allow for alignment of the pulleys. No counter weight needed just a little engineering Just and a suggestion. 7 2 Share this post Link to post Share on other sites
Lee1977 6,992 #112 Posted September 21, 2019 (edited) 19 minutes ago, wallfish said: Concerning the centering of the engine weight over the frame, you could use a jack shaft which would allow the engine to slide lateral on the frame. The jack will allow for alignment of the pulleys. No counter weight needed just a little engineering Just and a suggestion. I though of that too he has a problem with the clutch with the engine line up with the transmission pulley. If you move the engine over and add a jackshaft he will have a even less room for the brake. Edited September 21, 2019 by Lee1977 2 Share this post Link to post Share on other sites
wallfish 17,393 #113 Posted September 21, 2019 1 minute ago, Lee1977 said: I though of that too he has a problem with the clutch with the engine line up with the transmission pulley. If you move the engine over and add a jackshaft he will have a even less room for the brake. The jack shaft can be located any where. Drop it straight down or even in front of the engine but below the frame rail. 2 1 Share this post Link to post Share on other sites
Tractorhead 9,087 #114 Posted September 22, 2019 @wallfish I didn‘t know the wording „Jackshaft“, but that was also my first suggestion i meant before. It was just depending on Framelenght and Belt lenght, where it was located. With both sided Flanged Bearings, they’re mounted in long holes, it can also be adjustable to align the Belts. As an Advantage i see, that if the jackshaft is more to the Front, it can also being used with an added Pulley as direct driven PTO shaft for some later needs. I thinkin about two of the Bearings you can see in the pict middle up as proposal. in them the Axle „jackshaft“ can be clamped by 2 Screws for easy align and adjusting. 4 Share this post Link to post Share on other sites
ebinmaine 70,339 #115 Posted September 22, 2019 @wallfish and @Tractorhead I LIKE the idea of a jackshaft. I REALLY would like to have better weight balance. I have very limited space between the engine and steering fan gear but may fit it there. Like @Lee1977 says above I'll have to account for the position of the brake pedal in that equation. 1 Share this post Link to post Share on other sites
wallfish 17,393 #116 Posted September 22, 2019 With the extra shaft and pulleys you can easily adjust the size of the pulleys for more speed or more power or just match the original gearing. If needed, the brake pedal slides on the 3/4 rod so you can move that outward from the frame if necessary. Just use 3/4 lock collars to keep it in position. Some bending of the linkage rod will probably be needed or another jack shaft type rod can be used with a couple of levers to link the rods. Basically the same idea as the pulley jack shaft. 3 1 1 Share this post Link to post Share on other sites
ebinmaine 70,339 #117 Posted September 22, 2019 16 minutes ago, wallfish said: adjust the size of the pulleys for more speed or more power That's another reason I wanted to use that setup. Going from 23" to 30" tires I'll need to slow the tractor down dramatically. Even with 23s I RARELY get into 3rd. Nice drawings John... It's good for me to see a visual. I'll check the clearance for the brake pedal. Where would one procure the pieces to assemble the jackshaft? Also... I want to thank @Lee1977 for his input and alot of help with design and ideas. 2 Share this post Link to post Share on other sites
ebinmaine 70,339 #118 Posted September 22, 2019 19 hours ago, wallfish said: jack shaft can be located any where Keep in mind I'm using flat C-series steps too. The design of the belt system will need to clear them. 1 Share this post Link to post Share on other sites
wallfish 17,393 #119 Posted September 22, 2019 2 minutes ago, ebinmaine said: Where would one procure the pieces to assemble the jackshaft? Here's where I get stuff. You can find the bearings, shaft, pulleys, belts ect. ect. ect. Use 3/4 keyed shaft so the pulleys will lock in place https://www.surpluscenter.com/Power-Transmission/ 2 Share this post Link to post Share on other sites
ebinmaine 70,339 #120 Posted September 22, 2019 4 minutes ago, wallfish said: Here's where I get stuff. You can find the bearings, shaft, pulleys, belts ect. ect. ect. Use 3/4 keyed shaft so the pulleys will lock in place https://www.surpluscenter.com/Power-Transmission/ Nice. Thank you. I'll look and see what I've got for pulleys and do some thinkin'. Share this post Link to post Share on other sites
Pullstart 64,381 #121 Posted September 22, 2019 EB, you could run a holesaw through a factory belt guard and assemble the jackshaft accordingly, if needed. Use that new welder to build the angle iron belt guard frame a bolt a new cover over your outer pulley. The brake pedal moving outward shouldn’t be affected by that design and essentially the factory brake lever has a jackshaft... from the right pedal through the frame to your brake band If the C series step interferes, you can trim the inside a bit too. They’re thick enough, you can trim as needed and still retain their rigidity. This is all thinking from memory of tearing down a C series two summers ago and after a couple quality German beverages... sorry if it doesn’t actually work out on paper 3 1 2 Share this post Link to post Share on other sites
ebinmaine 70,339 #122 Posted September 26, 2019 Folks I'd like to hear your suggestions for the color of a Colossus. Like when you think of the word what comes to mind? We're thinking of a multiple color rig here and for some reason I think of dark colors. The engine block will most likely be high temp flat black. Possibilities could be All shades of black. Silver Copper Apple red NO "other brand" matches will be used but shades of other colors could be considered. What are your thoughts? Share this post Link to post Share on other sites
SylvanLakeWH 27,199 #123 Posted September 26, 2019 Hhhhhmm... Red? Share this post Link to post Share on other sites
Tractorhead 9,087 #124 Posted September 26, 2019 Red to Black fading... Share this post Link to post Share on other sites
ebinmaine 70,339 #125 Posted September 26, 2019 37 minutes ago, SylvanLakeWH said: Hhhhhmm... Red? Some portion or another will be red. Not the whole thing though. I'm curious to see what you all think would be good contrasting colors or whatever... 1 Share this post Link to post Share on other sites
