ebinmaine 69,682 #626 Posted May 17, 2020 6 hours ago, RandyLittrell said: Wherd did you get your bearings Eric? I need to do that kid on my loader tractor. Randy Got mine off of the fleabays... 8 bucks each set. I'll PM you a link. Share this post Link to post Share on other sites
RandyLittrell 3,887 #627 Posted May 17, 2020 Any idea how much weight a roller bearing will take? I know you will be beating on yours in the woods and I wonder if they would hold up to a loader? I didn't see any specs like that on the listing. Thanks, Randy 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #628 Posted May 17, 2020 42 minutes ago, RandyLittrell said: Any idea how much weight a roller bearing will take? I know you will be beating on yours in the woods and I wonder if they would hold up to a loader? I didn't see any specs like that on the listing. Thanks, Randy I don't know for sure. Check on McMaster Carr. Even though it's not their listing it would give you an idea. Mine is really not going to be that heavy. Maybe an additional 100-120 lbs on the front axle. Share this post Link to post Share on other sites
RandyLittrell 3,887 #629 Posted May 17, 2020 (edited) I think I am gonna try it regardless. If they can't handle the weight, I can always put a bronze spacer in it and grease it well. I went on Timpkens site and they said they are designed for heavy loads with moderate speed. They didn't say what those numbers where, but for less than $20 and some labor, I think it will be worth trying! Randy Edited May 17, 2020 by RandyLittrell 2 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #630 Posted May 17, 2020 https://www.skf.com/de/products/rolling-bearings/roller-bearings/cylindrical-roller-thrust-bearings Just to give you an idea, what bearings can carry static and dynamically. maybe you must switch the Language. 1 1 Share this post Link to post Share on other sites
Stormin 9,983 #631 Posted May 17, 2020 We call those, "Thrust bearings". 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #632 Posted May 17, 2020 2 hours ago, RandyLittrell said: I think I am gonna try it regardless. If they can't handle the weight, I can always put a bronze spacer in it and grease it well. I went on Timpkens site and they said they are designed for heavy loads with moderate speed. They didn't say what those numbers where, but for less than $20 and some labor, I think it will be worth trying! Randy I'm thinking you'll be fine Randy. A little grinding off the top and pop them in the bottom.... Easy fix. 1 1 Share this post Link to post Share on other sites
Stormin 9,983 #633 Posted June 2, 2020 Two weeks and no update. Tut, tut. 1 4 Share this post Link to post Share on other sites
ebinmaine 69,682 #634 Posted June 2, 2020 9 minutes ago, Stormin said: Two weeks and no update. Tut, tut. 3 Share this post Link to post Share on other sites
ebinmaine 69,682 #635 Posted June 2, 2020 (edited) I did actually get some spacers for the rear wheels in the mail today. I'm waiting 4 a needle scaler to arrive. My plan for cleaning the wheels is to mount them one at a time on the cinnamon horse and let it roll while I use a wire brush or abrasive wheel to remove the paint. The small spots that I can't get, I'll use the needle scaler. At some point I will also use the needle scaler on the engine block. Engine sheet metal will probably be a wire brush job.... Edited June 11, 2020 by ebinmaine 2 Share this post Link to post Share on other sites
Tractorhead 9,065 #636 Posted June 2, 2020 Use a sandblaster gun, simply selfmade and it’s better on cast iron than a nailer. a nailer can crack cast iron. 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #637 Posted June 2, 2020 53 minutes ago, Tractorhead said: sandblaster I thought about doing that but I'm leaving the engine assembled. I don't want flying sand going in the engine. Maybe I'll do a combo of needle scaler and wire brushing. 2 Share this post Link to post Share on other sites
Cvans 1,009 #638 Posted June 3, 2020 4 hours ago, ebinmaine said: 4 hours ago, Stormin said: Two weeks and no update. Tut, tut. Thought maybe you took a WH vacation. Nice to see this project still has life. 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #639 Posted June 3, 2020 8 minutes ago, Cvans said: Thought maybe you took a WH vacation. Nice to see this project still has life. Oh yeah.... Been busy with other stuff like firewood and yard fun... And I work in the construction industry which had been oddly busy. 3 Share this post Link to post Share on other sites
8ntruck 7,254 #640 Posted June 3, 2020 Careful using the needle descaler on sheet metal. Get too energetic with it and you will move the sheet metal around. 2 1 Share this post Link to post Share on other sites
Tractorhead 9,065 #641 Posted June 3, 2020 use instead of sand corn kernels or dryed peas. no sand contamination of the engine even no destroy of existing gaskets, color will be removed and rust but with no deep grinding the metal surface like sand does. 2 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #642 Posted June 3, 2020 4 hours ago, 8ntruck said: Careful using the needle descaler on sheet metal. Get too energetic with it and you will move the sheet metal around. I'll stick with traditional wire brush on the tins. 4 hours ago, Tractorhead said: use instead of sand corn kernels or dryed peas. no sand contamination of the engine even no destroy of existing gaskets, color will be removed and rust but with no deep grinding the metal surface like sand does. I'll check to see what I have available for light duty media. 1 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #643 Posted June 11, 2020 I got the mufflers in the mail today. Basically baby glasspacks. Patriot Exhaust Company H3121. They measure only 1-5/8" OD x 12" long. Six rows of flutes down through and into the "sound absorption material". They'll most likely be used as little stacks but the rest of the stack is yet to be determined..... 5 6 Share this post Link to post Share on other sites
Oldskool 6,660 #644 Posted June 11, 2020 Those are cute little buggers. Cant wait to hear what they sound like 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #645 Posted June 11, 2020 4 minutes ago, Oldskool said: Those are cute little buggers. Cant wait to hear what they sound like I've mentioned that I am usually right around five years old. Trina is about the same. As you can well imagine our level of extreme maturity dictated that we needed to hold a muffler up to our faces and yell in and out of them to see what the sound decrease would be. They definitely produce a deep tone. I'm looking forward to hearing what they sound like on the engine... 1 8 Share this post Link to post Share on other sites
Oldskool 6,660 #646 Posted June 12, 2020 Did they work? lol 1 Share this post Link to post Share on other sites
ebinmaine 69,682 #647 Posted June 12, 2020 29 minutes ago, Oldskool said: Did they work? lol Hehehehe.... Yeah... 4 Share this post Link to post Share on other sites
PeacemakerJack 10,743 #648 Posted June 12, 2020 Nice find on those Eric...I’ll be interested to see how those evolve into the final product. Nothing quite like a muffled “shouting” match 😂😂😂 At Least the neighborhood wasn’t disturbed...😂 3 Share this post Link to post Share on other sites
RandyLittrell 3,887 #649 Posted June 12, 2020 Looks like to me those are gonna make a nice "scale" sized stack! The oversize stacks kinda bug me even though I run one myself, can't wait to see how those come out!! Randy Share this post Link to post Share on other sites
ebinmaine 69,682 #650 Posted June 12, 2020 7 hours ago, PeacemakerJack said: disturbed She and I are Disturbed enough for a whole neighborhood.. 2 Share this post Link to post Share on other sites
