ebinmaine
The "Colossus" project
jebbear
I realize I haven't been around much lately, but I was beginning to wonder what I missed with all of this talk of outhouses! :ROTF:
  • Haha 3
953 nut
OK boys and girls,   you have been getting a bit    :offtopic:         here are a couple pictures of tractors to remind you of the correct topic.    :text-lol:
Image result for tractor outhouse
Remember, don't get :text-offtopic:  , OK         :hilarious:
  • Haha 6
ebinmaine
@953 nut
Richard you are officially
The Man....
Well played sir.
ebinmaine
@pullstart here's the tires that are going on the back.
They'll be on a narrow rim so the cross section will end up around 7".
  • Excellent 3
Pullstart
Are those 12” or 15”?  They look great!
ebinmaine
15"
Thanks!
They're going on an old set of camper rims I've had laying around.
(The other 2 rims are on the monster wood splitter)
Pullstart
Same bolt pattern as your hubs, or adapters required?
ebinmaine
Same same...
5 x 4.5.
I may use adapters to widen the rear but not correct the bolt pattern.
Pullstart
Awesome stuff!
PeacemakerJack
Those tires are going to look great on Colossus!  Seem to be quite similar to the ones that Dad put on Clyde.   They give a ton of bite when optimum traction is needed.  Can wait to see those in place on the machine :happy-bouncyshadowgreen:
ebinmaine
That would be because they are exactly and precisely the same
:D
I was seriously considering going one size up - to an 8-16... which would have been less expensive on the tires but I would have needed rims. I really wanted to use what I had on hand like we always try to do.
I'd like to be able to find some steel weights to go along with the fact that these tires will be fluid loaded.
@Mows4three Dave has a set in Western Pennsylvania that would work out perfect but the shipping is a killer.
I believe it was
@Ralph S  that had made up some hub mounted weight holders for his pulling tractor and perhaps I'll take advantage of a system such as that.
ebinmaine
One of our hiking friends is a fabricator by trade.
She made up the spacer to go between the frame and transmission.
It's 7 x 7 x 7. 5/16" thick. One side is solid capped and the other has a 5" hole to access the bolts.
I was originally going to mount it "hole side" down but Trina and I have decided to keep it "hole side" up because it will be EXTREMELY handy for holding general items.
Small tools. Gloves. Water bottle... Whatever.....
For reference the tiles are 12" square.
  • Like 4
Stormin
 Just a point, Eric. If your going to use it to put things in, I'd drill a hole or two in the bottom. You'll want dry gloves and water in a bottle. :D
  • Thanks 2
ebinmaine
I may do that just for kicks but we pretty much never leave our machines outside.
This one won't get used for snow plowing duty or any kind of inclement weather.
Stormin
Never say never. :P
  • Haha 1
Pullstart
Yeah... a breakdown might change the never to usually.  Shows might be the same type of rule breaker.
SylvanLakeWH
Nice friend and nice job!
You know, looks perfect size for a wine chiller... little ice, foam around edge to keep bottle snug, drain hole with drain tube, couple hooks for glasses off the side...very romantic for a :wh: date night...or you could add a compressor and go with a micro refrigerator unit off the PTO...
:ROTF:
  • Heart 2
ebinmaine
Breakdown here means we grab another horse and tow the nonrunner in the shop.
But shows. Yes. No enclosed space/trailer...yet.
ebinmaine
:ROTF:
:ROTF:
She really is awesome. Second only to my amazing Trina as the nicest person I know.
So that (adult beverage) cooler idea........ Hhhmmmmm......
We may have something there.....
Not wine for us .   But other drinks...
This is what it's all about. Sharing great ideas amongst our fellowship.
:lol:
  • Excellent 2
  • Haha 1
ebinmaine
Looking forward to this 4 Day holiday weekend because I'm going to be spending a little time getting organized and making a pile 'o parts.
The paint department has requested that.
I've been processing things in my head about how the brake and clutch linkage is going to connect.
One of the big challenges in my head with this project was figuring out what to do with the linkage because of the spacer between the transmission and frame.
Here's a couple pictures of the sheet metal from the 1977 C-160  I'm going to be using. Looks to me like if I can keep the geometry the same all I will need to do is lengthen the rod that goes to the brake shoe and figure out how to attach the clutch pedal return spring at a different point. Probably right to the side of the adapter I'm going to be using.
  • Like 4
ebinmaine
Also of note is that because the shifters will be back 7 inches I'll have a nice place to attach a flat metal plate to the top of the place they used to be.
Perhaps a good location for a gauge or two?
SylvanLakeWH
Cool idea - May want to account for waterproofing, as gauges will be lying flat and water / snow could pool on top and seep in...
Also may be a good spot for a beverage holder...
Edited by SylvanLakeWH
ebinmaine
Excellent points. Thank you.
This one won't be outside in the weather unless there's a breakdown or unforeseen circumstances as stated in one of the previous posts.
Perhaps farm tractor gauges would be a good idea? One would think that they would be weatherproof?
I believe the adapter itself is going to end up being the beverage holder on this one.
Big hole in it. 5" diameter I think....???
PeacemakerJack
Perfect for one of @19richie66‘s cups!😉
i like the idea of the gauge plate, if you are going to lay them face straight up though, make sure that their operation won’t be impeded.  Moisture and possible function could present a problem as most gauges are on a vertical surface of some sort.  I’m sure it has been done before—just a little research on the specific units you are planning to install would be prudent.
Cant wait to see what the paint department does with the newly acquired sheet metal!!!:greetings-clappingyellow:
ebinmaine
@PeacemakerJack
Awesome idea on the Richie cup.
We have a couple here. I see a photo op in the future.
So on those gauges...
Vertical versus horizontal is not something I had considered. Any thoughts on how I would find out information like that?
