Mickwhitt
Kohler K301 spark plug type
Mickwhitt
Hi all,  I am working through the engine restoration, sorting out the main possible issues such as bore and piston wear. Everything looks good so far.
I'm buying the parts I need as I go along as there is not an engine service kit available here as far as I know.
The spark plug fitted when I got the engine sits quite deep in the head, not coming down I to the combustion chamber.
Is this right or do I have the wrong plug?  Can anyone tell me the right plug for this engine? The wheelhorse data books say a champion H10 plug with an 11.2mm long thread.
I'm also wondering about the coil, should I try it with the original or get a new one from the off.
Regards Mick
953 nut
Image result for Champion H 10
Burnerman
I run an H10 in my K241. They are slightly recessed in the head iirc.
squonk
I use Autolite 216
richmondred01
H10
The Tuul Crib
Champion h10 here
Mickwhitt
H10 it is then, thanks gents, I just didnt think it looked right not sitting right down into the combustion chamber.
Regards Mick
Mickwhitt
I'm waiting for gaskets, seem to be hard to get hold of via my local mower dealer. They dont do a gasket kit so I'm having to order and buy them as I come to them.
The bearing plate gasket for the crank has different thicknesses to allow changing the end float on the crank and I'm struggling to source a set.
Coming on though, I'm pleased I decided to give it a go with your help.
Mick
Mickwhitt
Got everything back together, just trying to sort out the wiring harness so I can give it a try.
Mick
Mickwhitt
So, I refitted the wiring loom as it came off, no huge issues.
She turns over, but no spark.
Not sure if I have everything right so I'm going to check the wiring diagram and have a look in the morning.
One thing I noticed is there are only two wires going to the regulator. Dont think that would affect the spark.
Hoping the coil is not shot, doesn't look like an original unit so I might need to find a new one. Will a 12v coil for a car be ok?
Mick
953 nut
If that car is a 12 volt VW Betel then you will be fine!   The ignition coil has an internal resistor and most automobile coils don't have that. Tractor supply sells tractor coils with the internal resistor.
Before you go out to buy a new coil be sure you are getting 12 volts to the coil "+" side and your ignition points are set to .020" maximum opening which is a preliminary setting.
Edited by 953 nut
fat finger
ZXT
60s-70s fords also used an internal resistor coil. If you try for one at an auto parts store, tell them you want a coil for like a 65 mustang with a 289. Should be cheap and in stock.
Chrysler used a ballast resistor and GM used either a resistor wire or a ballast resistor depending on the year, so those are out.
Edited by ZXT
  • Confused 1
953 nut
:scared-eek:          Ford had two wires going to the coil, a resistor wire that was attached to the ignition switch and a non-resistor wire that connected to the "I" terminal of the solenoid. While the starter was turning the coil would receive 12 volts.
Image result for ford starter solenoid wiring diagram
ZXT
There I go thinking I know things! I know that I have a few ford script coils somewhere that are plainly marked as internal resistor. I was told by someone that they would've been off of what I mentioned above.. I wonder what they're really off of? A tractor maybe?
Mickwhitt
Why you little......
Just found out why no spark at the plug.
Brand new set of points fitted and the contact facts were covered in protective varnish  quick rub with Alox paper and off we go.
Schoolboy error, it's been a long time since I did my apprenticeship and learned the basics lol.
953 nut
Perhaps they were tractor coils, Ford went to 12 volts on tractors in 1965.  Is there a part number on them?
ZXT
I'll have to see if I can find them - they might be stored out where I keep all of my cars. I'll check the next time I'm out there.
Mickwhitt
I bought a new coil and condenser and made a bracket for it.
Now got a good spark and a fine looking coil mounting.
The ammeter had been bypassed and it turned out to be corrosion on the terminals not allowing current to flow. That's now working.
So do I knock up a temporary fuel tank and fire her up on the bench. Or mount the engine in the chassis to run it up for the first time?
Bearing mind it is just free standing on my bench and not bolted down. I may have answered my own question there.
Mick
953 nut
:text-yeahthat:         After all the work you have done we don't want it crashing to the floor!     :scared-yipes:
