interceptor84
312-8 Shutdown when PTO Engaged
interceptor84
Hey everyone! I have a mid 90's 312-8 that recently started shutting down when the PTO is engaged. When I jumper the two safety switches at the PTO, it runs fine. I have since replaced both safety switches and am experiencing the problem again. I have also jumpered the the seat safety switch to take that out of the equation. My question is what else should I consider either mechanically or electronically considering the troubleshooting I have done? Thanks in advance for any direction!
BESTDOGEVER
If it continues to run with the switch bypassed it means something in the switch circuit has grounded out and you have the fun of trying to find the gremlin in the wiring which is better than having it stalling under load. Look at where the switch wires branch off from the main line
AHenry014
If i were you, i would visit the wiring diagram for your tractor.  The safety switch run line is specific to each model.  I was going to guess seat switch but youve got that covered.
interceptor84
That would make sense now that i think about it. The issue started intermittently, as in when I'd hit bumps, which leads me to belive that the wiring is missing some insulation some where and has vibrated itself into a grounded position.
peter lena
think you called  it on that grounding idea, its common to have a wire that has been there for years to fray or ground from vibration . you might do a search and replace a few questionable areas. at that  time you could reroute and insulate to insure  its function. pete
953 nut
:WRS:
many of the '90s models have a seat switch relay and a start relay. Under the seat there is a model number that will tell us the year and we can give you the proper wiring information.
interceptor84
Model number is 73362, which i think correlates to a 1995. is a bad relay a possible cause? that was something I was considering replacing to see.
953 nut
Yes, it is a 1995. In the drawing below you will see that with the key in the start or run position and an operator (or any weight) in the eat the "Seat Relay" will be energized and the ignition (yellow) wire would be removed from being grounded.
I have not done this, but would suspect that in a quiet place you should be able to hear the relay open and close if the key is on and the seat is moved downward and then released. The yellow wire from the seat relay goes to the PTO switch and would not ground out the ignition in either position IF the seat switch relay is energized.
:confusion-confused:    Did we ever determine that nothing in the PTO switch itself isn't grounding out accidentally.
Look over the drawing (page 7-25 of the Demystification Guide) and see what you think.
Seems to me if you removed the "Seat Switch Relay" for testing purposes the yellow wire would be removed from ground with the PTO switch in either position. Worth a try!
Edited by 953 nut
Jeff Enders
New to your site and enjoying all the content. I am rebuilding my 312-8 and am wondering if there is a complete wiring harness for this model? When the unit was stored 2 years ago the PTO worked fine, however i got it out  of storage and the PTO is shutting the engine down. So I am also (besides the other great advice) considering replacing all the wiring. Thank you, in adance.
953 nut
:WRS:
@Jeff Enders,There are no new or reproduction wiring harnesses available but repairing yours won't be as bad as you may think. If the only problem is the PTO shutting down the engine then the seat switch or the wiring going to it is the problem. Depending on the model number there may also be a seat switch relay. Post the model number (located under the seat) and we can help you fix the problem.
Sparky
13 minutes ago, 953 nut said:
:WRS:
@Jeff Enders If the only problem is the PTO shutting down the engine then the seat switch or the wiring going to it is the problem.
Agree….I bet it’s the seat switch itself and for testing purposes it can be bypassed
Jeff Enders
Thank you to both members, I can't wait to have that first cup of coffee and hit the shop. I'll get back with you about the seat switch and relay. Also the wiring harness. Serial Number of unit. Thanks again, have a blessed day.
  • Thanks 1
ohiofarmer
I had that exact thing happen and it was the ignition switch itself..Replacing it cured the problem
Jeff Enders
Thanks 953Nut and Sparky, it was indeed the seat switch!
  • Thanks 1
