ebinmaine 70,733 #1 Posted August 27, 2019 We've removed the entire oil heat system from the basement and we want to put a small decorative but functional wood stove up in the great room on the first floor. We need to cut a hole in the chimney which is concrete blocks and likely a clay liner. How would one go about doing this? Share this post Link to post Share on other sites
rjg854 11,879 #2 Posted August 27, 2019 It would be a slow process, but a series of drilled holes around the circumference of the thimble you want to use would help keep the damage to a minimum so that you could then chisel out the hole to insert the thimble. Of course depending on the thickness of the block would make for the length of the bit you would need. An SDS drill or a rotary hammer would also make a big difference. 3 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #3 Posted August 27, 2019 are there any saw cutting/core drillers by you. we hire them occasionally if we need a hole drilled into manhole for storm pipes saves us time having them drill a 12 or 18 hole for pipe 2 Share this post Link to post Share on other sites
Burnerman 759 #4 Posted August 27, 2019 The liner is the problem. The tile is very hard. What are you venting? 2 wood stoves? Share this post Link to post Share on other sites
AMC RULES 37,146 #5 Posted August 27, 2019 What is the diameter of the hole you're looking for? Got a local tool rental? Might try there first. https://www.amazon.com/Core-Brick-Concrete-Block-Pilot/dp/B077RC2FTT/ref=asc_df_B077RC2FTT/?tag=hyprod-20&linkCode=df0&hvadid=309869401414&hvpos=1o8&hvnetw=g&hvrand=15120860865290059093&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004836&hvtargid=pla-582370321416&psc=1&tag=&ref=&adgrpid=63364097444&hvpone=&hvptwo=&hvadid=309869401414&hvpos=1o8&hvnetw=g&hvrand=15120860865290059093&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004836&hvtargid=pla-582370321416 Share this post Link to post Share on other sites
wallfish 17,494 #6 Posted August 27, 2019 (edited) Core drilling is the way to go. Wet core drill with the proper drill and bit is the best but it can be done dry too. Makes a nice clean round hole You can rent a wet core hand drill and proper size bit. Tile is no problem with a core drill but it's slow. That stuff is hard. I core drill concrete, brick, block, tile every day so if you have any questions about doing it let me know. Edited August 27, 2019 by wallfish 3 2 2 Share this post Link to post Share on other sites
ebinmaine 70,733 #7 Posted August 27, 2019 You folks are awesome. No way around it. 34 minutes ago, Burnerman said: What are you venting? 2 wood stoves? Back in February we had a major oil spill in the basement. After that we removed the entire oil heating system from said basement. We have a 2 flue chimney. 1 is for the large Fisher wood stove in the cellar. The one that used to be for the oil furnace is now going to be used for the small stove that we are putting upstairs. 1 Share this post Link to post Share on other sites
Burnerman 759 #8 Posted August 28, 2019 Ah. Got it! Wallfish sounds like the best guy to get info from. The only thing I’d recommend is get a SS liner for it from there up. It’ll ensure a tight seal at the new penetration and drilling the hole and compromising the liner are not an issue. Also safe and easier to keep clean. 1 Share this post Link to post Share on other sites
ebinmaine 70,733 #9 Posted August 28, 2019 37 minutes ago, wallfish said: I core drill concrete, brick, block, tile every day so if you have any questions about doing it let me know. jeez John it's too bad you're headed south next weekend instead of up here to Maine like you SHOULD be. I'd much rather throw money at you than someone I don't know. John to Mrs 'fish: Sorry I can't go to Jersey. Gotta work. In Maine. Yepp. 1 1 Share this post Link to post Share on other sites
AMC RULES 37,146 #10 Posted August 28, 2019 I bet Trina could do this Eric. When she does...we want a video. 2 Share this post Link to post Share on other sites
bc.gold 3,403 #11 Posted August 28, 2019 (edited) I make a paper washer ( album cover ) that I place between the core drill and the drive shaft, it makes removing the core drill so much easier. Also place a paper washer between the wire brush cup that threads onto an angle grinder, this was my first use of paper. Edited August 28, 2019 by bcgold 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #12 Posted August 28, 2019 Check with the supplier on the stove you intend to vent. You migh be better off side wall vent with the double stainless liner. Heres why. It the existing flue is to large and the run (Height) is to long, the warm exhaust gases will cool and wont make it to exhaust through the top. Hence they backvent, carbon monoxide. It oderless and can kill you. Just be carefull is all. I have seen this done wrong many times before. 2 Share this post Link to post Share on other sites
ebinmaine 70,733 #13 Posted August 28, 2019 6 hours ago, JERSEYHAWG / Glenn said: Check with the supplier on the stove you intend to vent Can't do that because it's an older stove that was a gift from a friend of a friend. I did have the local fire chief over to the house to inspect the site and approve what we wanted to do. ALWAYS appreciate a safety reminder. Thanks Glenn! 1 Share this post Link to post Share on other sites
ebinmaine 70,733 #14 Posted August 28, 2019 7 hours ago, AMC RULES said: I bet Trina could do this Eric. When she does...we want a video. Craig you KNOW she'd tackle that !!! Share this post Link to post Share on other sites
SylvanLakeWH 27,525 #15 Posted August 28, 2019 8 hours ago, JERSEYHAWG / Glenn said: Check with the supplier on the stove you intend to vent. You migh be better off side wall vent with the double stainless liner. Heres why. It the existing flue is to large and the run (Height) is to long, the warm exhaust gases will cool and wont make it to exhaust through the top. Hence they backvent, carbon monoxide. It oderless and can kill you. Just be carefull is all. I have seen this done wrong many times before. 1 hour ago, ebinmaine said: Can't do that because it's an older stove that was a gift from a friend of a friend. I did have the local fire chief over to the house to inspect the site and approve what we wanted to do. ALWAYS appreciate a safety reminder. Thanks Glenn! I would chat with a mechanical guy also. They spend their days calculating such things and making sure it has adequate draw... Also, put a co detector nearby... 1 Share this post Link to post Share on other sites
AMC RULES 37,146 #16 Posted August 28, 2019 1 hour ago, ebinmaine said: Craig you KNOW she'd tackle that !!! Well, sure... who else is gonna do it? 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,398 #17 Posted August 28, 2019 I have had too many close calls with fires .... pony up and hire a professional. It will save you in the end. Just my 2 cents 4 2 Share this post Link to post Share on other sites
ebinmaine 70,733 #18 Posted August 28, 2019 37 minutes ago, stevebo said: I have had too many close calls with fires .... pony up and hire a professional. It will save you in the end. Just my 2 cents Yeah we're still exploring the cost factor. It may end up being almost the same amount of money to buy a bit as it is to have somebody come in and do the work for us. IF we do end up doing it ourselves it will be inspected every step of the way by the fire chief. 1 Share this post Link to post Share on other sites
ebinmaine 70,733 #19 Posted August 28, 2019 1 hour ago, SylvanLakeWH said: I would chat with a mechanical guy also. They spend their days calculating such things and making sure it has adequate draw... Also, put a co detector nearby... Appropriate detectors are in place. Good idea on the HVAC person. There is a twin flu in this chimney that has a wood stove on it and does perfectly fine so I should be okay but I will ask. 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #20 Posted August 28, 2019 why did you get rid of the oil heat? Share this post Link to post Share on other sites
ebinmaine 70,733 #21 Posted August 28, 2019 4 minutes ago, jabelman said: why did you get rid of the oil heat? Notwithstanding the spill it's something Trina and I had been talking about for a couple years. The system we had was old inefficient cheap technology when the house was built in 2002 and it was beginning to require repairs. At the time of the spill the tank was dated at 19 years. if it was 20 years, or older, the DEP would not have let us reuse it. We've had two different oil heat installation and repair companies come in trying to seal a leak where the tank meets the filter. We were heading towards a situation of replacing the tank. Keeping in mind that we had already been mulling over getting rid of oil heat anyways we decided that replacing the tank was NOT an option. Gas heat was going to be a consideration but the installation cost alone was going to be between $300 and $800 depending on who we talked to. That does NOT count purchasing the system. That is ONLY the labor for installing it. Underground heat exchangers are not an appropriate primary heating system in our area because it gets too cold. They are also a little on the loud side when running and we spend a lot of time in that area. We've already installed a new high-efficiency electric 40 gallon water heater. Our electricity bill has gone DOWN in comparison to previous years when we were using oil to heat the hot water. This coming heating season we will switch over to electric heat to keep the house between 50° and 60°. Warmer than that, wood stove. Share this post Link to post Share on other sites
stevasaurus 23,065 #22 Posted August 28, 2019 Can't talk to you now Beaver, I have to go over to Eric's and inspect a hole in his chimney. 3 Share this post Link to post Share on other sites
jebbear 386 #23 Posted August 28, 2019 Just my worth, but don't totally rule out the gas option. Not sure what gas costs are in your area, but fortunately we already have gas installed in our area, and the daily operating costs alone are way less than electric. A few years back, I replaced our old furnace with a new high efficiency one with a heat pump, and the savings alone offset initial cost. Turned out to be a great investment. 1 Share this post Link to post Share on other sites
ebinmaine 70,733 #24 Posted August 28, 2019 47 minutes ago, jebbear said: gas I should have specified that a little better. We don't have piped in natural gas. We live in the middle of nowhere. Ours would be a propane tank installation. HUGE investment when you combine the labor cost and the price of the unit and then have to purchase propane at $3 to $3.50 per gallon. Share this post Link to post Share on other sites
Burnerman 759 #25 Posted August 28, 2019 10 minutes ago, ebinmaine said: I should have specified that a little better. We don't have piped in natural gas. We live in the middle of nowhere. Ours would be a propane tank installation. HUGE investment when you combine the labor cost and the price of the unit and then have to purchase propane at $3 to $3.50 per gallon. Propane is expensive to heat with. I worked 20yrs with Agway energy and 8 with Suburban-propane after the buyout. I understand what you’re dealing with Eric. That said, I have a HE on demand gas water heater that’s been awesome and sips LP. The other nice thing with gas is it’s easy to run during power outages. I have a vent free gas stove in the living room that we use occasionally that needs no electricity. if you have electric heat in the house already and reliable electric supply use wood and supplement with wood. Share this post Link to post Share on other sites
