flat head
briggs 18 hp opposed twin horizontal shaft
flat head
i have a engine with a broken rod does not appear to have any piston or cylinder wall damage ,how difficult is this to repair
Stepney
If the crank is still OK and there's no other damage, a standard rebuild should have you going again. While it's apart it wouldn't hurt to do the other rod, check the bores, valves, etc..
Bean701
Check the valves.  These motors are...well...junk imo
bds1984
Those engines are far from junk.  A large number of them have been installed on cheap mowers that are maintained by cheap owners which gave them a bad reputation.
flat head
this motor was serviced ,picked up by owner and when he got it home he started it ,it ran wide open, he let it run for about 10 minutes like this ,hoping it would idle down,it quit,it obviously had something going on with the govenor and it broke the rod front cylinder,if it were mine i would take it apart further and see what damage is done,at this point just looking for a replacement engine ,any one know of on for sale
flat head
anyone put a preditor 22 hp v twin on wheel horse
Edited by flat head
mispelled horse
