Butchy 53 0 #1 Posted August 26, 2019 I have a mid 90s 314-8 Wheelhorse Tractor. The tractor will not move in 1st gear or reverse. It will only move in 2nd and 3rd gear. Any help would be greatly appreciated!!! Share this post Link to post Share on other sites
953 nut 55,773 #2 Posted August 26, 2019 Chances are your gear shift lever is in need of some adjustment. This thread should get you going. Share this post Link to post Share on other sites
The Tuul Crib 7,337 #3 Posted August 26, 2019 10 minutes ago, 953 nut said: Chances are your gear shift lever is in need of some adjustment. This thread should get you going. to Share this post Link to post Share on other sites
Pullstart 63,096 #4 Posted August 26, 2019 @Butchy 53! Let us know if that’s not the issue, and maybe some more detail? Has it sat outside for a good amount of time? Can you move the shifter into 1st/reverse but it won’t move? Share this post Link to post Share on other sites
stevasaurus 22,865 #5 Posted August 26, 2019 Welcome to Red Square. We are going to need some more information. Is the shifter sloppy in the shift hole?? If so, there is a lock nut to loosen and then an Allen Head set screw (dog point) to make sure it is in the right place and then snug up. The dog point fits into the hole in the dough nut on the shifter. Tighten until tight and then back off 1/4 turn...then tighten the lock nut. Use a 1/8" Allen wrench. You can lift up the boot and come to the Allen set screw from under the console. Share this post Link to post Share on other sites
