tplace
312-8 Belt help
tplace
The belts on my recently acquired 312-8 are shot.  I found the correct belt that drives the rear wheels but I still need a belt for the PTO and the belt that drives the blades on my 42" side discharge deck.  The PTO belt was so bad that it broke last evening while I was mowing.  Can someone point me in the right direction?  Thanks in advance!
gwest_ca
Not likely the deck you have but the belts will be the same. Click on the picture.
Garry
tplace
This is GREAT!  Thank you!
