Pullstart
The Adventures of Hot Wheels
PeacemakerJack
That is a head scratcher.  Check all the obvious stuff first—no binding in the cable, connections from ram to hitch are good, make sure the belt to the pump is tight enough to keep it turning, make sure you have enough rpm’s, hose condition, what type of fluid are you running, etc...
Maybe @Achto @Shynon @WHX24 Will check in with their thoughts on HY-2 pump setup.  My only hands on experience is on my Cub and that one has worked so far.  When the engine rpm is half throttle or less it is pretty slow.  Dad’s on Clyde was a little slow at first but seemed to work pretty well this summer at the August plow day.
Pullstart
It has ATF in the pump and I’m running full RPM’s.  All seems fine as far as basics go, belt tension, etc.  When I help the plow, it lifts fine too.  When I started my food plot everything was fine, then I seemed to have lost pressure and it hasn’t come back fully.  There is no whine from the pump either.
Tractorhead
Hi Buddy,
it sounded to me, you reached maybe the max load of the Hydraulics, but i doubt about.
Is there maybe a safetyvalve on the Pump or on the steeringvalve, to restrict the max. Oilpressure, to protect the system?
I don‘t know, how much is the given Value, your Hydraulic shall be able to lift, but i can imagine, that ATF was to less viscosity, to be usable for.
In my experiences, the usability of Hydraulic system was also be needed the right hydraulicfluid in it’s viscosity
and there where several viscosity‘s of gear/ Hydraulicoil available.
As far as i know, your Hydraulicfluid is also the Gearoil, i‘m correct?
I would try a 80W Gearoil, with Hydraulic capability, what is recommanded at most Tractors,
i‘ve get this info from our local Tractordealer, when i planed my Hydraulics on my Horse, this may solved your issue.
ATF seems a bit to less viscosity for your purpose.
953 nut
It appears to me that the fulcrum of your new lifting rig is more than double the distance of the sleeve hitch, could be asking too much of the system.
Couldn't hurt to change out the ATF, it has been in there about ten years.        :hide:
Pullstart
I’ll start by replacing the fluid.  Is there a decent way to “flush” the system, or is there just a drain valve?  I think I have some mineral oil, I could pull a line and cycle the pump low, then top it off for a flush and drain again I suppose.  There are 5 gallon buckets of hydraulic oil around here from the snow plow business. :D
Shynon
I'm pretty sure you are gonna have to pull the pump and take the can off. As long as you are in there I would get a rebuild kit from @wheelhorseman and then refill with ATF, don't fill it too full. Look in the manual for how much it holds. Other things to check, how does it lift just the new hitch you made? Is it binding? Cable? if it's original I would also buy a new one if you are coming to plow days, nothing worse than breaking one and your done. Believe me I know that feeling, always travel with a spare cable and a spare drive belt.
Pullstart
It lifts great with no binding as long as I assist it, so I don’t believe the hitch is the culprit... just the load of the plow.  Also once it’s up, it stays put just fine.  I am unsure of the age of the cable, I’d guess 10 years Richard?  :D  The front of the cable has a solid link between the cable and the lift arm... I’m sure a spare would be a wise idea.  I’ll see if I have time to tear it out for inspection and fresh fluid.
953 nut
:hide:               Much older!     Cable was good when I bought it and I didn't replace it.
RandyLittrell
I'm going with the nut here :handgestures-thumbupright: . With the attachment point farther away, it has more up and down movement than back and forth. Looks like it has the lift the weight with less travel.
You could move the pivot farther away from the tractor
Randy
Pullstart
Could it be this easy?  The set screw was backed out and the pulley slid right off.  I’m going to put things back together and give it a whirl!  Maybe the pulley was slipping on the shaft!
Pullstart
  • Like 5
Tractorhead
Cool if it could be solved that simple.
Pullstart
That’s all it was!  I’m finishing the welding of the rear hitch, then maybe I’ll even smooth it a bit and throw some paint at it!
  • Excellent 8
PeacemakerJack
Time to go plowing Hot Wheels!!! And Kevin too!  :greetings-clappingyellow:
I love it when a solution is that simple.  It doesn’t always happen but it happens more often than not.  Thanks for the update...
Pullstart
Overkill, I’m sure, but I found this collar at the hardware store and decided I’d add it to the outside of the pulley, to double the clamping power.
  • Excellent 2
Achto
  On 10/7/2019 at 2:09 PM, pullstart said:
I think the second collar is a great idea. :handgestures-thumbupright: Might wanna grab a new belt for the hydro there Kevin. The cracks look pretty deep in that one.
  • Thanks 2
PeacemakerJack
I think that overbuilding is preferable to the alternative.  Seeing that situation, I’m gonna pull the cover on Clyde (Dad’s 953) and make sure his is tight.  Maybe I can convince him to do the upgrade that you have there!
Pullstart
You guys happy already?  :D
  • Haha 5
Stormin
 Personally, I think the pump is just not man enough for  the job. That's a lot of weight you've got hanging off the back. Also when the plough/low is in the ground, I doubt it would even twitch.
 I'd see about sourcing another pump and power it off the P.T.O.
OOPS! That's a reply to a post in the first part of the thread. Memo to self. Make sure you read ALL the thread before posting. :teasing-poke:
Edited by Stormin
  • Haha 4
Achto
For now.:lol:
Tractorhead
@Stormin
i ain’t doubt the pump can handle it, i have more clues to the Clamping itself.
Is it just fixed by the pressure of the Screws to the shaft, isn‘t it?
if so, i would mark the contactpoint on the shaft and grind the contact point’s of the shaft on one side a bit,
to have a small flat where the Screws are have a deeper point.
So the screws must be strongly worn out, that they can frict.
Similar to that pict‘s
if the clamp was that kind of
i would grind in contact surface like this
not as a groove spring but similar to.
ebinmaine
I'd like to add to that a little bit. General knowledge type stuff. All the set screws I install on a new surface I tighten them and back them out and tighten them and back them out four five six times before I leave it tight.
I'm really not sure where I got that trick from but what happens is that the set screw cup surface digs into the shaft surface a little bit more every time you tighten it. If you look at the clock position of the wrench as you tighten and loosen you'll see that it goes a little further each time you do that.
A word of caution when doing this. Be sure NOT to mushroom too much below the set screw or you'll have difficulty removing the item that is being set.
  • Thanks 2
Pullstart
Yeah EB, great idea!  Stefan, there is a flat on the shaft for the set screw to hold steady... but I now intend to loosen and tighten this new one a few times over!
Stormin
  OK! I've read what's been said about the set screw. (We call them grub screws.)
  Another way of doing, so you don't mark the shaft as Eric says, is to dimple the shaft enough for the set screw end to enter the dimple.
 Two ways of doing it.
(1) Spot through the screw hole in the pulley, then remove and drill deeper.
(2) Fit pulley and tighten screw enough to mark the shaft, then remove and drill dimple.
Pullstart
The hitch is smoothed and even primed!
  • Excellent 2
  • Similar Content
    • Pullstart
      By Pullstart
      5 big wheels, in various forms or stages.  One with melted wiring, one runner, one in need of an engine, one full project and one in the middle of nap time.  @953 nut thanks again for turning on my big wheel switch!
    • 12 hp Kohler
      By 12 hp Kohler
      Got a 953 and 414-8 from Big Red Fred the other day. Got a great deal on both of them. Both run great and I am very pleased with them. Got the 414 for my grandpa and the 953 was just to good of a deal to pass up, so now I got another tractor in my collection
    • bottjernat1
      By bottjernat1
      I wanted to show off my 953 i bought last year from the original owners son. I am very proud to own this piece of great american engineering. It was bought local in kendallville indiana the building is still standing where this tractor was sold. I got the greatest deal on it. It came with a snow blade, snow blower and a mower deck. i have since sold the snow blower because it was for a much newer horse. i am an originalist. This tractor i was told has only had an axle seal fixed and his dad many years ago slapped a new coat of paint on it. that is it never been rebuilt or anything else. It is one of my prizes horses.
    • M i k e
      By M i k e
      Boys, having problems with the front wheel alignment on my 1054a.  Seems as tho the tie rod is about 1/2" or so too short causing the front tires to pigeon toe.  Tore everything apart can find nothing wrong or bent.  According to WH parts diagrams, the 953 and 1054 tie rods are the same part number.  Perhaps one of you good fellas could give me the measurements of your tie rods so I can verify mines the correct length?  Maybe something else Im missing here?
      Thanks,
      Mike
    • admin
      By admin-(Admin)
      1 page 220.83KB
      Dated November 8, 1963
      Belt 1592 replaced by 1592A which is made to tighter tolerances and longer
      1963 model 953
