bottjernat1 2,190 #1 Posted August 22, 2019 Does anybody have a few photos of what the correct rear hitch looks like on a 69 electro 12 horse? My daughters has the cast hitch piece and is missing something else. it and the pin has lots of slop so im guessing we are missing another part of the hitch! Thanks 1 Share this post Link to post Share on other sites
Achto 27,994 #2 Posted August 22, 2019 You can make a piece to slide into the cast slot hitch to use for a hitch. If you don't have a lift cable for the slot hitch or if the cable is broken, you can make a metal bracket to hold it solid. I have done this on some of mine, used one of the tranny bolts as a mounting spot. Or you can find the draw bar hitch and add it on to the tractor, you will also require a longer mounting pin to add this on. The draw bar will mount around the slot hitch as seen in the picture below. 1 Share this post Link to post Share on other sites
bottjernat1 2,190 #3 Posted August 22, 2019 12 minutes ago, Achto said: You can make a piece to slide into the cast slot hitch to use for a hitch. If you don't have a lift cable for the slot hitch or if the cable is broken, you can make a metal bracket to hold it solid. I have done this on some of mine, used one of the tranny bolts as a mounting spot. Or you can find the draw bar hitch and add it on to the tractor, you will also require a longer mounting pin to add this on. The draw bar will mount around the slot hitch as seen in the picture below. ok awesome! Thank you i need to look at mine again. i think i have a hole lot of messed up going on . LOL thank you a million 1 Share this post Link to post Share on other sites
