boondockboost 34 #1 Posted August 20, 2019 Hey everyone, i was in need of some axle seals for my c141 hydro and i wanted to verify if the 6449 seal will work, i couldnt read the numbers on my factory seals and i searched some pages but I wanted to verify. Thank you! Share this post Link to post Share on other sites
pfrederi 17,876 #2 Posted August 20, 2019 6449 is correct for Sundstrand hydro transaxles it is CR /SKF 11124 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #3 Posted August 20, 2019 Check the trans section under the pinned ones at the top . That should help. Also check the vender section as well. Share this post Link to post Share on other sites
boondockboost 34 #4 Posted August 20, 2019 5 minutes ago, The Tool Crib said: Check the trans section under the pinned ones at the top . That should help. Also check the vender section as well. Thank you! Share this post Link to post Share on other sites
boondockboost 34 #5 Posted August 20, 2019 7 minutes ago, pfrederi said: 6449 is correct for Sundstrand hydro transaxles it is CR /SKF 11124 Okay excellent is that what the trans type is a sundstrand? This tractor is still new to me Share this post Link to post Share on other sites
pfrederi 17,876 #6 Posted August 20, 2019 Transmission oil filter is on the right side. Later WH switched to Eaton Hydros their oil filter is on the left rear. Share this post Link to post Share on other sites
The Tuul Crib 7,337 #7 Posted August 20, 2019 25 minutes ago, boondockboost said: Thank you! Check amazon they're quick and cheaper than napa. Share this post Link to post Share on other sites
pfrederi 17,876 #8 Posted August 20, 2019 Couple things. My bearing house charges $3.52 for a real SKF 11124. if you see a CR boxed seal on Ebay etc it is already probably 10 years old.... 1 Share this post Link to post Share on other sites
boondockboost 34 #9 Posted August 21, 2019 19 hours ago, pfrederi said: Couple things. My bearing house charges $3.52 for a real SKF 11124. if you see a CR boxed seal on Ebay etc it is already probably 10 years old.... I was able to get the seals for aeound that price at a local place, one thing i noticed was with the seal out it was leaking fluid so after i pur the seal in i wanted to add sone more fluid and i read they take 10w30 or trans fluid which ever it had but I'm almost certain theres gear oil in my trans, it smells just like it does that sound right? Share this post Link to post Share on other sites
pfrederi 17,876 #10 Posted August 22, 2019 20 hours ago, boondockboost said: I was able to get the seals for aeound that price at a local place, one thing i noticed was with the seal out it was leaking fluid so after i pur the seal in i wanted to add sone more fluid and i read they take 10w30 or trans fluid which ever it had but I'm almost certain theres gear oil in my trans, it smells just like it does that sound right? I doubt a hydro would function very well if it was filled with 90w Gear oil. Smear the dip stick on a clean paper towel what colr is it. Red ATF tan 10w-30 1 Share this post Link to post Share on other sites
boondockboost 34 #11 Posted August 22, 2019 3 hours ago, pfrederi said: I doubt a hydro would function very well if it was filled with 90w Gear oil. Smear the dip stick on a clean paper towel what colr is it. Red ATF tan 10w-30 Its oil colored tan but man it stinks like gear oil it dosent seem as thick as 90w but it sure smells like gear oil Share this post Link to post Share on other sites
pfrederi 17,876 #12 Posted August 22, 2019 (edited) 32 minutes ago, boondockboost said: Its oil colored tan but man it stinks like gear oil it dosent seem as thick as 90w but it sure smells like gear oil I believe there are now light gear oils around 40w I do not know what they smell like (or there could be a mix of gear and regular oil who knows what evil lurks in trannies). I know that gear oils smells distinctively awful. i would suggest that you drain the system an completely refill it with the cheapest 10w-30 you can find and run it until it gets hot. Then drain it again and use better quality 10w 30 (or 10w-40) and a second new filter Wix 51410 Edited August 22, 2019 by pfrederi Share this post Link to post Share on other sites
