Similar Content
By She's a Newbie
I bought a C-160 beautifully restored but I plan on using it for a dependable mower. The deck is totally shot. I have a 42" deck that is currently on a 310-8. Will it fit on my C-160?
Also, do most of you members use a lawn mower jack to work on your wheel horses? If so, which one would you recommend? Thanks you!
By Ifixoldjunk
I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
By Ifixoldjunk
So I’ve picked up a 310-8 recently and I’d like to start finding attachments for it.
the route I’ll probably go is picking up a parts tractor to rob attachments off of. I’d like to know what tractors have interchangeable attachments with the 310. Would a blackhood or a b series have similar attachments?
I’ve always been a bolens guy, so this whole wheel horse thing is new to me. Thanks for any help.
By CB1993
Hello. I just purchased a 1277 today and was wondering if there was any info on the mower deck. Is there a manual for this deck? What kind of belt is used? I have attached some pics. Thanks for any input.
By Rob R
Hi guys need you help have a 42" side Discharge Deck (Triple Blade) mower deck, mounted on a C-81, that is in bad need of an outside Spindle (Mandrel) the pulley on top is # 5877. The bottom bearing is toast. so I poise the following questions. Note pics attached.
1. Does any on have one of these for less then a Kings ransome?
2. Is it possible to disassemble and install an new bearing from like NAPA?
3. All three spindles have NO Zerk grease fittings can I drill and add some...... if yes where on the housing is the best place to do this.
Thanks feel free to add any other options......
