Franky Figs
Plow angle lever
Franky Figs
I am a newbie who has a  1979 C-81 and I am looking for the hand cable that controls the angle of the plow ! The iron handle is there but the cable that has the lever you squeeze is broken ! Thanks Frank
pfrederi
If you mean item 19 it was a rod not a cable.  However you could use some cable and clamps to replace it
Edited by pfrederi
ebinmaine
I'd actually recommend doing what Paul said. Replace it with a cable. gives you a little bit of flexibility when you're trying to take the plow off and on  the tractor.
By the way. Welcome to Red Square!
Edited by ebinmaine
stevasaurus
I think it is actually like #109 wire, you can buy it at ACE, etc.  :occasion-xmas:
Franky Figs
Thank you all for the info and  the picture of the plow with the parts numbered ! I believe I am pretty certain that I need  parts  number 26,27 and 28
Burnerman
If you have a welder it’s a very easy part to make. I can get you a close up pic if you’d like.
SylvanLakeWH
:text-welcomeconfetti:
