![DavidM](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By Aaron Coffman
Hi Red Square Community,
I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
By wwww12345
Hello all, a buddy of mine has a wheel horse 417-8 that needs a rebuild. Does anyone know where he could get a rebuild kit? Thanks!
By chuck NJ
Right side of the mower deck is about 1.5 inches lower than the left side. For the life of me, i cannot find what i am to adjust to level the deck. I called the manufacturer (never do that again) looked at available manuals but this machine is not listed. I looked at you-tube but my machine is not discussed. The back of the deck rests on two hooks and the front locks in place with spring pins. Two blades that are even, tire pressure same but i am half blind which hinders my observation. If anyone has a clue i would be grateful... chuck nj
Wheel Horse 211-4 Tractor Mower
Model #: 32-11B402
32-11B402 ..... 1988 ..... 211-4 Tractor 4 speed
Engine: Briggs&Stratton 11hp Model: 252707 Type: 0624-01 Code: 87091611
Oil: SAE 10w-40
Deck belt (for mower blades): 4L760W, Line: NBH
