mrc 810 #1 Posted August 12, 2019 hi men, refurbishing my friend's 42 inch SD deck. he seems to be missing what wheelhorse calls a 'special washer'. its # 32 in the parts diagram. i'm thinking it's teflon/nylon type of washer. hardware store type of thing or buy from toro? i'm thinking you leave the 2 bolts that hold the spring loaded tension bar a little loose so the spring keeps the belt in tension. correct? thank you mike in mass. Share this post Link to post Share on other sites
oliver2-44 9,695 #2 Posted August 12, 2019 Are these the parts you are referring to? Glenn Petti one of the great Vendors here has them. Mower Deck: Washers & Spacer Bushings Fits on the idler slider bar: Parts #107675 & #107674 Two pair of Washers & spacer Bushings for basically all Wheel Horse mower decks from 1974 to 2008; for B & C-series and later 200 & 300-series tractor decks. A pair of metal washers to fit over the upper washer is included, for extra support, mounting instructions included. These allow the slider bar to move freely so the idler deck pulley maintains the correct belt tension for the spindles. $6 for the kit: (two metal washers, two upper plastic washers and two plastic Bushings). Plus, 1 oz = $3.50 shipping. 2 Share this post Link to post Share on other sites
peter lena 8,583 #3 Posted August 13, 2019 classified as " shoulder washers ", use silicone grease on them , deck side, pete Share this post Link to post Share on other sites
mrc 810 #4 Posted August 13, 2019 thank you oliver2-44 and peter lena for the quick reply. Share this post Link to post Share on other sites
