Hubbieswheelhorse 0 #1 Posted August 12, 2019 What is the difference between the two transmission and how can I differentiate before taking apart? Share this post Link to post Share on other sites
pfrederi 17,879 #2 Posted August 12, 2019 Pages 5-14 of this manual will get you going (Click on picture) Share this post Link to post Share on other sites
Racinbob 11,229 #3 Posted August 12, 2019 The difference between the 5003 and 5010 is the tab that the brake band bolts to. It's vertical on the 5003 and at about a 45° angle on the 5010. Also the 5003's and the early 5010's had ball bearings on the brake shaft and later 5010's had needle bearings. 2 1 Share this post Link to post Share on other sites
stevasaurus 22,866 #4 Posted August 12, 2019 If you really want to know everything about those 2 transmissions, I suggest paging through this thread. It has everything you ever wanted to know about the #5003 and the #5010 transmissions. Excellent information and lot of it in this thread. Bob is right though...it is the brake band mount that is used to identify those trannys from the outside. 2 Share this post Link to post Share on other sites
