Bob Nakon
Old mower deck double D
Bob Nakon
Hi all,
I'm rebuilding my old mower deck. It has the double D spindles. Does anyone know where I could look at an assembly or schematic drawing of these spindles?
Thanks,
Bob
daveoman1966
Do these help...  The schematic is the 42 and 48 spindles..
Edited by daveoman1966
  • Excellent 2
Bob Nakon
Thanks Dave!  Man, your parts all look good.  I’m using the shafts I got from you, but my dome washers are all split.  Looks to me that the shaft is upside down in the drawing. The longer flats need to go down towards the blade I think.  Somehow I got hold of a almost new spindle housing that is about 1/2” longer than the others.  Too bad, it is almost new!!
Bob
daveoman1966
I'm not sure which DD shafts I send....length wise, that is.
The LONG flat on the DD spindle shaft is for the PULLEY.  The Spindle Cup and Blade with DOME WASHER fit to the SHORT end of the spindle shaft.  I don't have any decent dome washers but surely they can be had somewhere....I'll check around.
