WHNJ701 4,165 #1 Posted August 3, 2019 on my 96 mustang gt I have slight coolant leak on the intake manifold. anybody ever use this stuff I figure for 8 bucks it's worth a try. it's a limited use car that I put about 1500 miles on a year and it sits all winter. Share this post Link to post Share on other sites
ol550 830 #2 Posted August 3, 2019 Don't remember the location of the coolant ports but why risk it? Coolant could also leak to the inside. 1 Share this post Link to post Share on other sites
prondzy 3,883 #3 Posted August 3, 2019 Just remember if it can plug a hole (leak) it can plug a radiator, thermostat, heater core........ good luck 1 Share this post Link to post Share on other sites
rmaynard 15,919 #4 Posted August 3, 2019 If it's a vehicle that you value, I would fix it right. When I young, we used Bars Stop Leak. Pour a can into the radiator and it would seal pinholes. Then when the car started overheating and the radiator had to be cored, we learned that we were clogging the radiator as well as plugging the leak. My dad used to pour black pepper into his radiator. He was cheap. Same results 2 Share this post Link to post Share on other sites
Pullstart 64,573 #5 Posted August 3, 2019 18 minutes ago, rmaynard said: If it's a vehicle that you value, I would fix it right. When I young, we used Bars Stop Leak. Pour a can into the radiator and it would seal pinholes. Then when the car started overheating and the radiator had to be cored, we learned that we were clogging the radiator as well as plugging the leak. My dad used to pour black pepper into his radiator. He was cheap. Same results I’ve heard of the black pepper trick, and raw eggs too. If all else fails, you’ll have a sweet breakfast! 2 1 Share this post Link to post Share on other sites
Stormin 9,983 #6 Posted August 3, 2019 17 minutes ago, pullstart said: I’ve heard of the black pepper trick, and raw eggs too. If all else fails, you’ll have a sweet breakfast! Last resort get you home tricks only. 2 Share this post Link to post Share on other sites
bc.gold 3,403 #7 Posted August 3, 2019 1 hour ago, jabelman said: on my 96 mustang gt I have slight coolant leak on the intake manifold. anybody ever use this stuff I figure for 8 bucks it's worth a try. it's a limited use car that I put about 1500 miles on a year and it sits all winter. If it has the V6 intake manifold leaks are common, you'll need a fuel line disconnect tool and a T-40 socket electrical connections are plug n play. Depress the schrader valve on the fuel manifold to release pressure before attempting the disconnect. It's an afternoon or evening job. Share this post Link to post Share on other sites
WHNJ701 4,165 #8 Posted August 3, 2019 3 minutes ago, bcgold said: If it has the V6 intake manifold leaks are common, you'll need a fuel line disconnect tool and a T-40 socket electrical connections are plug n play. Depress the schrader valve on the fuel manifold to release pressure before attempting the disconnect. It's an afternoon or evening job. it's the 4.6 v8, I think they are known intake issues too Share this post Link to post Share on other sites
squonk 42,554 #9 Posted August 3, 2019 Aluminum, plastic, it never fails. Share this post Link to post Share on other sites
wfrpalm 218 #10 Posted August 3, 2019 Fix it right. Share this post Link to post Share on other sites
adsm08 2,670 #11 Posted August 3, 2019 It will mess with the coolant temp sensors and you can never get it all out. Your leak is the intake gaskets around the water jackets or the coolant cross-over pipe. The 4.6 intake manifold is stupid easy to remove, just be careful with the two long bolts at the water neck. This repair is not expensive or difficult enough to do it wrong. The gasket set is under $50, if you have even the most limited of mechanical ability you can do the job yourself in under 3 hours with just basic hand tools. I don't even break out the 3/8 drive stuff for that intake. Share this post Link to post Share on other sites
adsm08 2,670 #12 Posted August 3, 2019 3 hours ago, bcgold said: If it has the V6 Any Ford with a GT package has the biggest engine offered that year. The exception is the 04-09 Mustangs where the GT had the 4.6, but there was a 5.8L V8 in the Cobra. 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #13 Posted August 20, 2019 I dug a little deeper and found the intake manifold has a nasty crack at the thermostat housing. off to the shop it went for a new manifold. I see the new replacement ones have a metal cross over instead of plastic. as for the magic sealer it went back to walmart. Share this post Link to post Share on other sites
