Similar Content
By dannyo
Hi all. I am new to the Wheel Horse world and I have a question about attaching a tiller to my 875 before I start spending money. Based on what I've read so far, it sounds like I can use the RT-366 tiller without having the 8-3311 PTO assembly, is this correct? If so, does the RT-366 belt attach to the hydrostatic motor if there is a double pully (#6887) installed?
By D_Mac
Picked this up today because I wanted the deck for my 875. The 875 has no deck so I figured this one is better then none at all. Question is what do I do with the rest of it??? 875, was told the engine needs rebuilding. Been sitting in a barn last 20+ years. Steering wheel is broke. Both front tires are shot and coming off the rims. Original paint. Plow needs the arm to turn the blade. Its repaired in a fixed position. Worth more in parts or as whole? Not sure I want a big project. What do you all suggest???
By KC9KAS
My 875 is missing the small spring that is attached to the cam/neutral plate.
The part number is 1230 and NLA.
Anyone have one or know the dimensions of the spring?
Thank you!
By admin-(Admin)
1 page 196.25KB
1 page 82.24KB
Dated February 17, 1965
232613 Kohler belt nla Use 231605
232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
1964 model 854
1965 model 855
1965 model 875
Starter/generator belt
Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
1964 model 1045
1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
1965 model 1055
1965 model 1075
By BMW1
A previous owner modified replaced the motion control lever on my 18 auto with what appears to be a John Deere motion control lever.
The 18 auto I have has the single slot for the motion control lever.
Are the motion control levers for the single slots interchangeable between the different D series or do I have to find one from a 73 18 auto?
Thanks.
