Similar Content
By Reddart
So I had a stupid plastic funnel that I used to do oil changes that had a tube connected to the funnel part, I guess so the funnel could swivel, a slight angle to fit different areas.
well, when I was taking the funnel off after doing my oil change on my C101, the tube part popped off and fell in the crankcase. Of course can’t see anything through that hole, tried for a while fishing it with a coat hanger, but no sign of it at all.
perhaps I’ll be lucky and it just sits somewhere in the crankcase without touching any moving parts.
By WheelHorseC101
When I start my engine it will die once i change the throttle from idle to full throttle and when I switch the cold start throttle to what ever down is. It will just die every time
By wheelhorsekid
I got a C160 automatic today. I already own a C101 8 speed. The first thing I noticed when driving each one is the C101 seems faster, and seems to not bog down as much up a steep hill. I bought the C160 for more power and speed but now I am regretting my purchase as it feels the C101 drives "stronger".
I also noticed how much smoother my C101 is compared to the 160. I know the rubber motor mounts are the reason. Questions is can I upgrade the 160 to the same set up for a smoother operation?
Thanks for any answers anyone can give me.
Thanks!
