troutbum70 857 #1 Posted July 26, 2019 Uni-DRIVE # 2988185 this is the number on the sticker on the housing. Looking for the part number so as to try and order from napa. This on a 417-8 17 horse kohler. Share this post Link to post Share on other sites
daveoman1966 3,762 #2 Posted July 26, 2019 (edited) Why not get the OEM axle seal. .. Edited July 26, 2019 by daveoman1966 In deference to GARY.... I stand corrected and edit my post Share this post Link to post Share on other sites
ebinmaine 68,386 #3 Posted July 26, 2019 5 hours ago, daveoman1966 said: Why not get the OEM axle seal Agreed. Or call Lowell on the vendors section. Around here Napa was more expensive and I still had to wait a few days. Might as well support our own... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #4 Posted July 26, 2019 Click on the picture Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #5 Posted July 26, 2019 8 hours ago, daveoman1966 said: Why not get the OEM axle seal. Find it here. Just enter your model # as ; 417-8 and go to the page TRANSAXLE or transmission. https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO/417-8//1/ The seal is part # 6449... about $10 each... Dave I believe the 6449 is for the hydro models. 1-1/8" ID x 1-5/8" OD Go down the list at psep to see the 8-speed models. I see WH part number 100443 which is 1-1/8" ID x 1-3/8" OD for the 417-8. Napa or SKF # 11050. A parts manual shared by more than one tractor model is always a problem unless you have an original copy. Garry 1 Share this post Link to post Share on other sites
Pullstart 63,096 #6 Posted July 26, 2019 Is this what we all are? Quite the read in that patent app! I will from now on, or until I forget, refer to it as a power drive mechanism! 1 Share this post Link to post Share on other sites
pfrederi 17,884 #7 Posted July 26, 2019 SKF 11050 is $3.55 from my bearing supply house and is a steel shell. Some of Toro's are plastic 2 Share this post Link to post Share on other sites
troutbum70 857 #8 Posted July 26, 2019 Thank you Gary and pfrederi 100443 was the number I was coming up with, just was not sure if that seal was used in hydro or 8 speed or if they were the same. What tractors used the 10 pinion limited slip if any one knows the models? I believe my particular tractor is an 8 pinion. Share this post Link to post Share on other sites
pfrederi 17,884 #9 Posted July 26, 2019 13 minutes ago, troutbum63 said: Thank you Gary and pfrederi 100443 was the number I was coming up with, just was not sure if that seal was used in hydro or 8 speed or if they were the same. What tractors used the 10 pinion limited slip if any one knows the models? I believe my particular tractor is an 8 pinion. 10 pinions were used on Charger/Electro and Raiders long before your 417 was born. Share this post Link to post Share on other sites
troutbum70 857 #10 Posted July 26, 2019 Yes I new the 10 pinion was earlier than my 417, I thought it may have been used on the D Series. Share this post Link to post Share on other sites
midpack 891 #11 Posted July 26, 2019 5 hours ago, pfrederi said: SKF 11050 is $3.55 from my bearing supply house and is a steel shell. Some of Toro's are plastic I ordered 2 of these for $5.00 delivered on Ebay Share this post Link to post Share on other sites
pfrederi 17,884 #12 Posted July 26, 2019 1 hour ago, midpack said: I ordered 2 of these for $5.00 delivered on Ebay Be interested to know when you get them if they come in a green SKF box Note seller says brand is after market. Also picture does not show the outer edge of the seal as being green. SKF brand seals have a green sealant applied to the outer edge.... Share this post Link to post Share on other sites
ebinmaine 68,386 #13 Posted July 26, 2019 1 hour ago, pfrederi said: Be interested to know when you get them if they come in a green SKF box Note seller says brand is after market. Also picture does not show the outer edge of the seal as being green. SKF brand seals have a green sealant applied to the outer edge.... I ordered some off of eBay a few months ago that came in a plastic bag with a paper label and no boxes. They are not green painted like a standard SKF seal but they are definitely a metal cased seal and seemed of good quality. I have them in 2 tractors. One is the Cinnamon Horse and that has a few months of run time on it and they seem fine so far but who knows what the entire life span of them will be... Can't remember exactly what I paid. I ordered six at a time. $3 each? $4 each? 1 Share this post Link to post Share on other sites
