Firebug
Attach o magic adjustment.
Firebug
I put a new pto to deck belt on today.  1/2x97 for the rd deck. I have the attach o magic adjusted all the way out, there is still a lot of slop in the belt to where it will come occ the deck pulley. Any thoughts?
The Tuul Crib
Sounds like the belt is alittle long.
tunahead72
Agreed.  What tractor and mower are you talking about?
Firebug
314-8 with a 42 inch rear discharge
lynnmor
Are you sure that the deck is mounted properly in the mid hitch?  The fork should be straddling a pin.
Firebug
It is. I just mowed with it the other day with no issues. The new belt is a hare shorter than the old one, I figured that was the stretch in the belt from use
tunahead72
I'm starting to think @lynnmor is on to something...
I just did a quick check of the 42" rear discharge decks that were available for the 314-8, and came up with the 05-42MR03 in 1985 and the 78350 in 1993-2001.  Both of these specify drive belt #108834, 1/2"x98".
So, what belt did you just install?  And is this a new problem since you installed it, or was there a similar problem with the old belt?
Also, what engine does your tractor have?  It should be a Kohler, either K321, Magnum14 or Champion14.  I don't know if it makes a difference, but it might help.
rmaynard
Do you have the belt in the correct PTO position?
The Tuul Crib
That might be the problem. Good point!
Firebug
It’s a 93 with the magnum 14. I put on a 1/2x97 which I was told is the belt in another post I had on there. It is on the inside groove on the pto.
Ed Kennell
The new belt is shorter than the old one that worked, but the new one is too long.     This doesn't compute.  :confusion-confused:
  • Haha 1
  • Confused 1
daveoman1966
The belt MUST be in the INNER MOST 'V' of the PTO pulley.  I bet that is the problem.  If not that, maytbe the deck isn't mounted  correctly...OR  T two pulleys on the front Mule Driver...the Flat Idler and the V pulley are wrong.  They should be about 4" diameter.
Ed Kennell
:wwp:          I'll take a guess that the belt is not on one of the mule drive pulleys.
Edited by Ed Kennell
Ed Kennell
Attach-o-MAGIC...…...:scared-shocked:
Ed Kennell
Just wondering......Is the new shorter belt still too long?
Could the old belt be a 5/8" and the new one 1/2"?
Tonyp
also check the round shaft rod ( side to side ) on the tach-o-matic mount  that the  tension adjustment screw secures against, make sure it's not bent backwards slightly. .  This is NOT uncommon.
