DDK319
414-8 Gear Oil, Shift Boot and Low Range Questions
DDK319
Hi All,
I have a 414-8, 80's model (no Toro stickers, not sure of the exact year).  When I bought it about a year ago, it had been sitting for quite a while, and went into and out of low range no problem to get it into the truck.  However, since I got it home, I have been unable to get it into low range.  This is a bit of a pain when using it to snowblow, so I'd like to fix that issue this summer.  The mower deck is currently at the welder getting rot repaired, so I decided now is the time.  Since the gear oil looks rough anyway I figure the first step is a flush (or two) and some new fluid.  Also a new shift boot (mine is split).
With the backstory out of the way, on to my questions:
1) What is the correct weight and quantity of gear oil?  I plan to flush with 2 quarts of diesel.  I have seen 80/90 gear oil and 90/140 gear oil suggested.  It's been mid 90's the past few days, but I snowblow with it also.  I can swap for winter if I need to.
2 Any easy way to verify my year by serial number?  A search found some links to serial number lookups, but the links I found were dead.  Hopefully once I have a year I can find parts diagrams and breakdowns.
3) Anyone know the part number for the shifter boot?  I'd like to get that on order ASAP.
Thanks!
Dan
stevasaurus
You should be able to use straight 90 wt gear oil year round in Mass.  Your trans should take 1 1/2 to 2 qts.
414-8s were made in years 1986 model # 31-14K801...1987 MODEL # 31-14K802...1988 MODEL # 31-K803...1989 MODEL # 31-14K804
Dust cover (boot) is #3577   :occasion-xmas:
The hi/low range relies on a shift fork that slides a fork gear between 2 other gears.  You may have bent or broke this fork.  If so, you have to open the trans to fix it.  It is possible that things just aren't lined up just right.  Try rocking the horse while trying to shift into low.  It is important, that you do not try to force things.  If you do break that fork, it could get caught between gears and cause more damage.  Flushing with diesel and new oil may help also.
The Tuul Crib
:text-welcomeconfetti:to :rs:
:wwp:
gwest_ca
1986 used Kohler K321 engine.
1987-89 used Kohler M14 engine.
Post all the numbers you can find and we can likely ID the tractor model number.
Garry
peter lena
use a razor blade to cut off old shiftier boot , use SILICONE GREASE to install the new one, on shaft and boot hole, very easy , pete
DDK319
Thank you all very much for the info!  Could anyone tell me the correct part number for the blades for a 42in rear discharge?  The ones I bought on amazon have 3/8 holes, not 3/4.  Bummer, because now getting the new blades will likely be the holdup when the deck gets back from welding.  I'm tempted to try to drill out the holes on the ones I got, but I am concerned about them going out of balance.  I have a stepped bit I could use at low speed, and then just bore it smooth with a 3/4 bit once I have stepped it to about that diameter.  Bad idea?  I don't mind returning these and getting new ones if I can find the right part #.
Everything else is coming together great!
Pics are tough because she's on a lift in my garage draining the rear end fluid.  I attached a couple pics of the label on the engine, and one in the garage.
Thanks All!!
Dan
20190724_183906.jpg.37e958b98f965b14313feab0305c80fc.jpg20190724_202440.jpg.34085661ff09e8dda61eb47268804763.jpg20190724_181736.jpg.82d1ba67ad54c062c9b576ad6f62936a.jpg
pfrederi
Blades are very tough steel i think you step bit would not be up to the job.
Blade set WH # 106635  or Stens 350108 (but they are single so you need 3)
DDK319
Thank you pfrederi!  The Stens are available with next day shipping on Amazon Prime, so they should still be here about the same time as I get the deck back (which will be tomorrow or Monday).  Much appreciated!
Edit:  Aw nuts.  Only one Stens left and I need 3.  Back to the search!
Edited by DDK319
bottjernat1
I recommend stens products my late dad was a stens dealer. I have lots of stens parts now. not very many blades tho. other parts engine parts you name it. Only thing is i wish they would let you buy items in bulk without being a dealer! I have tried to i repair stuff for folks now that my dad is gone I dont want to be a dealer until i get a house. But i could use like air filters and oil filters in bulk. i have some now but have had a few times where have a steady supply would be nice
DDK319
bottjernat1, good to know about the parts, bummer on the dealer status. I just ordered 3 sterns blades from ebay, guaranteed to be here Tuesday.  I suppose I can wait that long to mow again!
gwest_ca
According to the info we have available your tractor is a 1987 model 31-14K802. The engine was made in 1986 and landed on a 1987 model tractor.
The 601524 spec number was used on the 1987 model only.
Click on the pictures
Garry
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • nylyon
      By nylyon-(Admin)
      I think I am selling my 1987 414-8 with plow, weights and chains.  Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H.  In that search I stumbled onto a forum which was one day old.  There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike.  Mike convinced me I didn’t need a plow, but an entirely new tractor.
      About a week or so later, I found this 414–8 for sale, and bought it.  I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
      About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
      I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor.  I am looking for $550, but like I said this tractor is a bit of a legend!
      I have cleaned it up since the pictures were taken.
    • F. Marra 17
      By F. Marra 17
      Gets the job done
    • F. Marra 17
      By F. Marra 17
      No problem cutting through
    • F. Marra 17
      By F. Marra 17
      I have a late 80's 414-8. my transmission has a slow oil leak. it leaks slow so its hard to see where it is coming from. i get a small puddle/stain on the floor center under the trans after a few days of non-use.  is there a usual problem area that leaks? or is there anyone in the NJ area that can be recommended to repair the trans? I am sure due to its age that gaskets or seals may be shot.  the tractor sat for 10+ years at my office on a shelf.  It has ran well the past 3 years for me.  I would like to fix this leak if possible.  Any advice or help is greatly appreciated.
      THANK YOU,
      Frank
