toroboi265 0 #1 Posted July 24, 2019 part that i need is 92-7082( not 92-7084) https://www.amazon.com/gp/product/B008TSVM0W/ref=ox_sc_act_title_2?smid=A16NVWA9G6RLXM&psc=1 but i paid 50 bucks for this lawn mower and not looking to sink almost that much into one part... any recommendations. was thinking this might work https://www.amazon.com/d/Lawn-Mower-Parts/Replacement-Pulley-Craftsman-Poulan-Husqvarna/B004CAREBM . but not sure i have been looking but want second opinions. mower is a toro wheel horse 265 6 speed Share this post Link to post Share on other sites
wallfish 18,786 #2 Posted July 24, 2019 (edited) Measure the diameter and bore sizes to find one of that size. You can look here https://www.surpluscenter.com/Pulleys-V-Belts/Idler-Pulleys/ Tractor Supply carries idler pulleys. Edited July 24, 2019 by wallfish 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,844 #3 Posted July 24, 2019 There is a list of Stens pulleys and their dimensions here you can download Garry 1 Share this post Link to post Share on other sites
Lee1977 7,456 #4 Posted July 24, 2019 (edited) If the center grove isn't welded and it has a sealed bearing you can drill out the spot welds.t The sealed bearing will also have a sieve pressed in the center that nocked out and put in the new bearing. The flat idlers I have fixed had a 1623 bearing 1 3/8" O.D. 5/8" I.D. and 7/16" wide should find the bear for around $5.00 on Ebay. The cheap Idlers usually don't have sealed bearings. These are mule drive idlers. i have done the other belt drive idlers just don't have a picture. Edited July 24, 2019 by Lee1977 1 Share this post Link to post Share on other sites
toroboi265 0 #5 Posted August 27, 2019 I'm going to keep all this in mind but I got the go ahead to just buy new or re-manufactured it was around 50 where I found it. But thanks guys for the help and I will definitely keep all this info incase I need to get another one. And the thought to drill it out never even crossed my mind. Share this post Link to post Share on other sites
