chev0545
sunstrand hydro
chev0545
anyone on here rebuild these hydro's?
daveoman1966
What model tractor / Sundstrand ???
chev0545
1975 c-160 pump model # 90-1140
pfrederi
What is the issue?  Lack of power, leaks
bc.gold
 If your 90 is an inline the repair manual has been up loaded to redsquare. If your unable to locate I have a copy archived online but need an email address to send permissions.
chev0545
ran out of power.changed oil & filter,didn't help after it got hot
chev0545
wouldn't know where to start
bc.gold
From tractor data I see that your hydro is a belt driven unit you need to find the correct service manual inside you'll find  a diagnostic section.
Symptoms along with suspected part malfunction, in addition the test ports will be shown along with pressures expected from each port.
Those test ports are the holy grail, no secret shall remain untold.
Not sure about your hydro but mine can not be bench tested before or after a rebuild due to the oil flow circuit, oil flows through the unit back into the transmission.
daveoman1966
The issue you have....power loss when at operating temp...is a classic sign of internal wear.  There is no cure, except surgery.  Your PUMP and Hyd MOTOR both need rebuilt.  It is pointless to rebuild one and not the other as the oil is common and the internal components are nearly identical.  It is the contaminated oil that wears out the parts.  This is NOT a difficult task, but is a tedious one.  Download the 4 section repair manual for starters.  I can provide sources to buy new seals to cure the leakage problem. I have also uploaded an Excel SS on this Piston-to-Piston model(s), but no sure where the moderators list it.
I've rebuilt many of these...you can too as all you do is resurface internal parts on fine grit sandpaper...for the most part.
chev0545
dmeyer2259@comcast.net
