Raider 134
Solid tires
Raider 134
Hello, I was sondering if anyone knows if it is posible to mount some solid rear tires on my raider 12? I use it like a work horse(pun intended) and im constantly running over nails and screws and getting flats, The worst part is that the tires are not tubless so it is a pain to get a new Tube and fix it(because delivery takes a couple of days if not even weeks) so i could use some solid tires but id prefer to keep the original rims. So if anybody knows if it is possible please leave a comment!.
Edited by Raider 134
953 nut
A year or so back I remember John @wallfish had an experiment where he used some low expansion foam to fill tires. Perhaps he can fill you in (yes, pun also intended) with the results.
  • Haha 1
rjg854
I don't really want to post this :naughty: but. ..
I've heard about foam filling tires, which I believe would take care of your problems of anymore flat tires,  but then I don't know if your rims would ever be usable if you wanted to change tires. It would be a royal pain to get them tires off and to clean  the wheels.
wallfish
:WRS:
Pull the tires off the rims and tape up the rims painter's masking tape which will save them from the foam, or at least most of it. You can search foam filling tires on youtube.
Edited by wallfish
ebinmaine
John I tried to search and I wasn't able to find anything that looked like it would actually work.
I've been thinking about doing this as well. Have you found anything that is good long-term without having the phone crush down under heavy weight inside the tire?
ebinmaine
@Raider 134
Welcome to redsquare!
wallfish
I only did it on a walk behind snow blower tire but I can jump on it and it doesn't crush. @wh500special ? I think, was thinking water may effect the foam and make it closed cell which is much more dense and would certainly hold the eight of a tractor
The Tuul Crib
If you could get a solid tire you would
have to be able to have a split rim or
something like old truck tire rims.
RandyLittrell
In my neck of the woods, there are some tire places that fill them with foam.
Randy
pfrederi
I have a New Holland 930b finish mower it weighs about 600 lbs.  it has 4 foam filled wheels.  Thyt do get out of round sitting over the winter but after one mowing they are round again.
ebinmaine
Randy
I've read about that on the internet but never tried to price it around here. I understand it's quite expensive to get done, also permanent.
I've considered to purchasing new rims and new tires and having them done but really can't justify the cost of paying someone else to do that.
keeping in mind that we like to do as much DIY as we can, that's my interest in this thread.
Raider 134
:WRS:
Randy
Well that works but its a pain in the *** to change Tires, and from what i have heard the foam crumbles and wont hold the tractor anymore!
wallfish
https://www.americanindustrialtire.com/foamfilled.htm
What about coating the inside of the tire with a thick layer of flex seal? That should keep it from getting flats
https://www.flexsealproducts.com/product/flex-seal-liquid-rubberized-coating/
Edited by wallfish
ebinmaine
I've heard of commercial duty tubes that claim to resist or reseal. I can't make any claims or recommendations for them one way or the other.
JaysHorse
I watched test videos on YouTube and the results weren’t good. I wouldn’t bother with the foam trick.
Stepney
I've always heard more bad then good in the way of foam..
Something we used to do at a scrapyard I worked in. They had a Model A Ford jitterbug as a pusher. On small wheels similar to our WH's. They had HD inner tubes with thick Conveyor belting cut to the ID of the tire, acting like a barrier. (Maybe even 2 or 3 layers of this?) The tires were then filled with .. waste oil.. of all things. That yard has since closed due to EPA issues .. if you could believe it..
However we never ever got flats on that car. Maybe it's worth a try?
  • Haha 1
roadapples
I know this has been discussed before, but I would use tubes and slime em'.
RandyLittrell
The tires they do around here are filled with a urethane foam that's permanent. They do lots of skid steer a and construction equipment. I am not sure my but cheeks could tolerate solid tires!!
Randy
  • Haha 2
19richie66
We had two 26x12-12 tires filled with foam and they came out to weigh 198 pounds each. They are great for rear weight but you aren't going to remove them or install them without wheel studs or a jack. :laughing-rolling:
  • Like 5
ebinmaine
Bahhh....
I have my honey for the heavy work.
And a chain falls....
  • Haha 1
troutbum70
I agree with putting the slime in, I have never used it myself. But I have heard okay reports around here from some that have.
oliver2-44
At my previous work around the dams we had a skid steer and a sky track with commercially foam filled tires. i was involved with getting the replacement tires for the old sky track filled.  The old tires had been worn down to running on tire cords and foam.  They reused the old rims, but I don't know how they did it. The shop that did it offered 3 densities of foam.  With all the rough rock around the dams, these were the way to go.
About 6 months ago I picked up a set of ag tires on JD 12" rims that are foam filled.  I haven't  used them yet, but as Richie said, they are heavy.  I would say commercial foam filling is the way to go if you can sacrifice the rims and handle the cost.
SPINJIM
The Amish around here don't have problems with flats.  They use steel wheels.  And so did the early steam tractors.  I think that solid rubber tires would be just as rough a ride as steel wheels with rubber cleats.  Look for steel wheels from an old walk-behind tractor.
Or how about skid-loader tires that have a deeper and heavier tread so nails won't penetrate.
   Jim
Edited by SPINJIM
McGrew
 I have 2 pieces of equipment at work, and had the tires foam filled, as they both operate in some tough conditions.  Nails and screws on the pavement are the norm.  The forklift and scissors lift both had sem-pneumatic tires when I had them filled.  A local forklift dealer filled the tires.  I don’t remember the exact cost, but it was not cheap...  The good news is the tires have been filled for several years, and have never had a problem.  I recommend the OP find a local forklift dealer or forklift service company and price the service.
 Wallfish, I have not tried Flex Seal on tires, but bought several spray cans of their sealer to try to waterproof a wooden box.  The box was only about a cubic foot, but it would have taken many more cans to do the job because the Flex Seal was so thin...  I abandoned that plan.  I would not recommend that product, but your results may vary...  Danny
Howie
I thought about the Flex Seal in the quart can to see if it would seal the side wall on one
of these mower tires but did not try it. did not know how thick the stuff is and did not
want to waste my money so to speak.
  • Similar Content
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
    • kvtprs
      By kvtprs
      I have a 12hp kohler that when its running it pops threw the exaust and you can see a small amount of flame in the muffler. What does this mean and how do I get it to stop? Thanks Paul
