sergt3
deck advice 42 inch deck
sergt3
I need to know if a 42 inch rear discharge deck will mount and work on on a tractor with a 42 inch side discharge:text-thankyouyellow:
Racinbob
Pretty much all decks for the B series thru 1977, all C's, 300's, 400's and 500's will interchange. We could use a bit more info to give a certain answer. :)
midpack
If its attach a matic it should. You'd need a different belt
sergt3
the 42 rear discharge is coming off what looks like a 10 horse b model 8speed..going on a c120 automatic side discharge and they are both attach-a-matics .:text-thankyouyellow:
608KEB
That will work. Off subject, but a 42" side discharge  will not work on a 520H. The deck wheels will hit the rear tractor tires. You would  have to widen the bracket that the deck wheel is attached to.
